Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Best "low beam" out HID solution?
    Lexington, Kentucky
    Default Best "low beam" out HID solution?
    Bit of Background.
    I have just installed ddmtuning's 4500k, 55w, 9006 HID lights in my 95 e34. Got the low beam error. Tried the Bulb out warning (BOW) plug in device from ddemtuning and they did not work. I think they were resistors. This problem bugs me and I want it fixed.
    I have searched the various e34 forums and have yet to find the definitive and complete DIY to resolve the low beam warning many e34s get when installing HID lights. There have been suggestions of resistor, capacitors and relays and so on.
    None have been really complete enough especially those that say “just plug in a capacitor” Well, what type of capacitor and what type and where do I connect the capacitor. Do I need it for each low beam? You get the idea.
    The most complete DIY HID bulb out solution I have found is the e34 M5 write up by Dave McLaren and Garrick Louie. It uses a relay to work with the high beam to fool the LKM. This I may try.
    Does anyone else know of any solutions? TIA
    If you would tell us the DETAILS about the LKM installed, then I might have an answer.
    In case of part numbers
    LKM-B   ECE   61.35-8350375
    LKM-L   ECE   61.35-8350376
    LKM-B   ECE   61.35-8356017
    LKM-B   ECE   61.35-1379372
    LKM-L  J  61.35-1379374
    LKM-L   ECE   61.35-1390356
    http://dd.jpn.org/BMW_HP/20040911/index.shtml
    http://dd.jpn.org/BMW_HP/20040911/LKM376.pdf
    or
    Resistor: http://dd.jpn.org/BMW_HP/20020126/index.shtml
    Use google for the translation from Japanese to English if necessary, the pics and the drawings are basically enough for someone who knows a bit about electronics.
    Jan 2008
    Sweden
    I could never get Dave McLarens relay solution to work on my car, so what I did was: went to the scrapyard, got hold of 2 side blinkers, mounted them in parallel !
    Best part, if you use white blinkers and mount them nicely, you get 2 new engine bay lights! I just hid them under the lampcovers..
    Lowbeam warning is history, and the 5w bulb is real easy to change should it blow!
    Lexington, Kentucky
    Is this what you need? I appreciate any assistance possible.
    Lexington, Kentucky
    Quote Originally Posted by Bo525i View Post
    Very interesting, Wish I had a scrap yard with BMWs locally. Even so, any 90s era BMW should have side marker lights that should work. Question- how would this be different than a "resistor" solution which would be like the failed BOWs I tried from ddmtuning? Thanks again
    Thanks Russel.
    Loewe and then in USA-L Version. That I have unfortunately never had a chance to lay hands on and open it, as in Japan we only have EURO and/or J-specification LKMs.
    But I posted on the German 7 Forum some time ago a tip from the German E34 Forum for the Loewe in EURO verion (which has 4 relais isntead of 3 in US version: low beam, high beam, front fog lights, rear fog lights).
    See the red arrow which points to a red dot on a line, cut this line and the alarm will be interrupted. But you will also get no warning when the low beams are really not working.
    http://www.7-forum.com/forum/24/bese...non-84243.html
    Jan 2008
    Sweden
    No difference actually as the filament in the bulb acts as the resistor.. And you can basically use any bulb in any kind of socket.. One guy in germany soldered in a 1.4w bulb in parallell to the same effect and covered it in shrinkwrap!
    Feb 2007
    GreenHills East-Philippines
    hmm.. would this work in my "f/fog light" warning issue as well? it started also when i installed 3000k hid's in fogs
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
    Lexington, Kentucky
    That means your technique may not work for me. Even so, I may give it a shot with some bulbs I have lying around. who knows?
    Lexington, Kentucky
    Thanks Russel.
    Now that seems brave! Hate to ruin an LKM. However, you should be able to repair a solder cut if it does not work.
    BTW, I have attempted to pull my LKM. However it does not want to seem to come out.
  1. HID install works but "LOW BEAM" warning?
    By Guelphguy in forum 5 Series BMW
    Last Post: 04-11-2007, 03:58 PM
  2. Fixed the "Low Beam" error message . . .
    By gale in forum 5 Series BMW
    Last Post: 03-04-2007, 11:07 PM
  3. HID "low-beam warning" relay
    By rockyfeller in forum 5 Series BMW
    Last Post: 10-02-2004, 08:53 AM
  4. Installed HID's- Now "Low Beam" Error Message.....
    By Don McAdams in forum 5 Series BMW
    Last Post: 07-25-2004, 09:45 AM
