well I took a look but it's similar to the E36 design. I need to completely remove the sunroof mechanism to fix it as it's acting loose.
ok .. u need to push the sunroof to the "up" position (so the back is tilted up).
take a look from the outside of the car.. and u might see them:
- there are two clips on each side of the sunroof, between the two panels (one panel comes up while the other panel slides back).
these clips are forward facing.. u need to find the front of them (looks like a long pin about 1/8" in diameter and about 2" long and press them towards the OUTSIDE of the car .. this will release the bit that holds the inner sunroof piece.
if u can't see em just fish around with your finger a bit from the inside of the car above the lower panel.. and hook it around.. ul find em.
then all you do is slide the roof piece forward and lift it out through the back of the sunroof opening
then.. sit inside the car and look at the side of the sunroof mechanism.. there are three adjusting screws.. one forward, one middle, and one at the back of the sunroof.. u can adjust these and set em to whatever height suits u.
should fix u up..
as far as putting that slider piece back in.. it's a bit of a bitch to do.. but ul figure it out with a bit of messing around. one of my clips broke entirely so i didn't bother putting it in
unfortunately leaving it this way will allow you to see a bit of the roof mechanism when it is closed.. on each side there will be a bit of metal showing.. not something i notice really
hope that helps.. feel free to pm me if u have any more questions
-inc
'91 e31 850
'90 e34 535
'02 CBR F4i stunt/track bike
'07 gsxr 750 stunt bike
that sounds cool ... you gave me the guts to try it. so I'll do it this Friday cuz it's getting really annoying on highways. by the way the interior mechanism also moves heavily, or vibrates when I close it, I don't know if I need to replace anything to fix it. so if you can suggest me any repair kit to buy before I start so I wont have the roof opened until I do so.
Thanks dude.
well.. chances are either a tooth or two is/are broken.. or maybe the mechanism itself is misaligned.. try opening it up (push so back comes up) and have a look inside.. see if u can see anything in there.. like i mentioned i just removed the interior piece entirely.. i doubt i will ever fix it as i'm sure the pieces are expensive as hell and/or hard to find.. maybe i should take some pics. i remember i still owe u some pics of my system.. i'll do em tomorrow
-inc
'91 e31 850
'90 e34 535
