Results 1 to 10 of 11
Thread: Need help for auto tranny service on 540i
    Sep 2006
    Gold Coast
    Default Need help for auto tranny service on 540i
    Been through all the old post on it, one thing I cant find is what is the right type of ATF to use in the zf slush box for 540i in Australia? It appears the states have slightly different products. Over here our suppliers only has ATF Dexron III grade available, but from reading the old posts it seems the 5HP30 uses ATF Dexron IV or higher?
    Anyone in OZ can help?
    Sep 2006
    Perth, Western Australia
    hello fellow ausy, i am in perth and have just done a trans service because the pan was starting to leak.
    There is a place called Auto Classic in perth who sell the correct fluid. DO NOT USE ANY FLUID as this will destroy your box. Go to a dealer as each box is different (blue code etc).
    It cost me nearly 300 just for the fluid but it now runs as new with smooth shifting. Also note it is not easy to fill and make sure to check the level when the box is cold and not hot as I found out. This caused a strange noice in the morning until I found out that it needed another half a liter.
    Sep 2006
    Gold Coast
    Ta, thanks mate.
    I already hit Shell Australia up about the ATF LA-2634, and its not available in Oz.
    Feb 2005
    try Penrite ATF BMV. Fully compatible and Spec sheet available at www.penriteoil.com
    http://www.penrite.com.au/html/s02_a..._id=55&dsb=581
    Not normally stocked but can order readily through Autobarn in 4lt containers RRP $44.05 at fraction of cost of Shell/BMW product.
    Apr 2005
    So Cal USA
    I did my first round of ATF change with Royal Purple Max ATF. it smoothed out the shifts. I should be doing the second round of ATF change soon.
    95 M-sport SOLD now NSX
    NEPA
    how did u do that exactly? im thinking about servicing my auto.
    Sep 2006
    Gold Coast
    Quote Originally Posted by nimbus4
    Thanks dude! Penrite it is then!
    Sep 2006
    Good luck I would not use anything else than the correct fluid. You might save a couple of hundred on fluid but will cost you more in changing the transmission.
    Go and get the correct fluid from a BMW service center.
    Go to my website and look for europeantransmissions, instructions there for the different kinds of trans.
  1. Tranny service for my 95 530i
    By Alpinewhite in forum 5 Series BMW
    Last Post: 12-29-2018, 06:39 AM
  2. Replies: 33
    Last Post: 07-03-2006, 10:28 AM
  3. 540i auto to 540i manual
    By Dazbut in forum 5 Series BMW
    Last Post: 04-08-2005, 12:07 AM
  4. gotta spare tranny? (94 auto 540i)
    By wec5 in forum 5 Series BMW
    Last Post: 02-24-2005, 05:53 PM
