Results 1 to 8 of 8
Thread: cluster bulbs
    Wellington,New Zealand
    Default cluster bulbs
    what is the part number for the cluster bulbs?I noticed to day that although my SI is lit the little compartment next to it is not so i cant see the inspection or oil dervice indication.....i can see something but its very dim.....or is this a caps issue(the odometer lamp also is intermittent)
    Nov 2004
    Split, Croatia
    Take out your instrument cluster, open it (by untwisting black thumbscrews - you'll figure it out once you have it outside), inspect all the bulbs and their contacts - clean all the contacts and replace the bulbs (they're cheap). You can also check for bad capacitors while you're at it.
    Nov 2004
    Middle England
    My bulb information (extracted from cross-references on this forum) for a late 89/early 90 E34 :
    6 - 1.5 watt bulbs - (probably only from BMW dealer ) - ‘ON’ most of the time and are for :
    auto gear indicator
    check instrument display
    service indicator
    odometer
    3 - 3 watt bulbs - gauge lighting
    13 - 1.2 watt bulbs - only 'ON for short periods and are for :
    warning lights
    turn signals
    high beam indicator
    '90 535iSE Auto (AE+EAT) 123k miles
    '86 F288 69k miles
    '06('89)- PGE 2.0DOHC Turbo
    '03 A160LE 19k miles
    1914 Stellite E2A (no odometer!)
    (+ others I daren't mention here)
    www.pyghtle.com
    anyone have part # i had an idea the etk was wrong
    1.5W62111391260?
    3W 07119978372?
    Quote Originally Posted by zygoteer
    auto gear indicator
    service indicator
    odometer
    warning lights
    turn signals
    high beam indicator
    Sep 2005
    Goulburn Australia
    If they're the same type of tiny bulbs I was always changing on my E12 they are dealer only parts but are pretty cheap. You might be best buying a 'card' of them and going for a discount.
    Cheers
    Wingman
    '89 525i/A Exec 193000kms
    '94 Subaru Liberty AWD Wagon
    Looking for Merc 300TE
    NSW, Australia
    Nov 2005
    Southern NH
    Quote Originally Posted by wingman
    Instrument cluster lamps are available online at:
    http://www.autohausaz.com/
    Been there, done that, got the full display now...
    Fred W
    (oo 00 oo)
    95 325i
    94 540iA
    97 Z3 2.8
    Nov 2005
    Precious !
    Holy cow ! Even found reasonably priced heated mirror replacements ! Way cool !
  1. Capacitors in a 92 e34 Cluster (blue cluster)
    By BMWDriver in forum 5 Series BMW
    Last Post: 07-20-2009, 08:30 PM
  2. cluster bulbs - same as Mercedes
    Last Post: 12-08-2006, 09:47 AM
  3. Replies: 4
    Last Post: 12-03-2005, 03:43 PM
  4. ::.. How many bulbs in the cluster?
    By Qube in forum 5 Series BMW
    Last Post: 12-01-2005, 11:03 PM
  5. Instrument cluster bulbs
    By romus in forum 5 Series BMW
    Last Post: 10-11-2005, 09:31 PM
