I'm thinking it's a streteched chain or broken tensioner.
Here's the ETK parts i'm looking at..
http://www.realoem.com/bmw/showparts...87&hg=11&fg=25
hard to say. From behind the pc it sounds like an waterpump going bad. The tensioner should make a more destinctive rattle sound. Good luck in finding it, hope itīs the tensioner though. Thatīs cheap and easy to fit.
Yeah. Though I hope never to have the occasion to hear what a failing tensioner sounds like, I'd imagine it wouldn't sound like this. This definitely sounds like an accessory bearing to me. Do any of the pullies look a bit cocked out of alignment?Originally Posted by Jose
You could always pull the belts off and see if the sound goes away.
If you do troubleshoot it down to a failed accessory bearing, stop driving the car until it's fixed. I don't mean to make you paranoid, but when the alternator bearing on my dad's Suburban failed (long ago) - he ignored it until it turned into a full metal-on-metal squeal which ended in an engine fire. It wasn't bad, since the alt was at the top of the engine - but, just.. a warning.
would not have expected that!Originally Posted by Mobius
the chains dont really stretch kriss,
check your pulleys bro.
and stay off the track!!!!!!!!!
I was going over the car again. I'm talking about the bottom belt on the right hand side on the car.
The noise is seems to be coming from this pump, the one on the right of the pic. http://www.bimmer.info/forum/attachm...tid=1076&stc=1
the belt it on really tight, there is no play in the belt at all. I have a good feeling this is causing the loud noise. I never adjusted belts before, can anyone give me some advice (hint hint...lowell) on how I can loosen it.
i dont think it will be as simple as just loosening the belt man
is the a/c compressor.
If it is a suspect of the noise...just dis-com-booberate the belt and see if the noise goes away.
If it does, then your a/c compressor clutch or compressor is bad.
Drop $1000 at the a/c shop and pass go.
Check out Harbor Freight for a mechanic's stethoscope, they have them cheap and a scope is great for finding the source of a scary sound.
a 4 foot screwdriver is my stethescope
I feel so inadequate now, with my little Craftsman stuff.
