Get a allen key and cut it off 1" down...
Originally Posted by
ryan roopnarine
the allen key doesn't fit the fill hole unless you grind it down, and using the hex head bolt and vice grips just ruined the vice grips, especially after i put the breaker bar on the twisty part of the vice grips.
Maybe you did this already... I just got a big allen key (like 8") and cut off the end, then I had a little stub I could stick in the female end of the diff bolt and turn the other end with a 14mm box end wrench.
You can get a metal-cutting blade for your grinder or circular saw for a few bucks at home depo. Don't have a circular saw, you say? What kind of man doesn't have a circular saw! Go buy one!
- Robin
Robin
72 Chevy K10
01 E39 M5
