started headliner project and did the front section (tourings have a 4 piece headliners vs the one piece board of a sedan) epoxied a piece of wood into the hatch to eliminate the always crap falling out panel that never fits right with aftermarket headlining material, made a hole to access the screw in event of motor failure, to replace the motor its easy enough to just take the header out. swapped in a rear light cargo area single switch dual bulb light for the standard map light style dome light.
not wild about the color but its better then the flapping original, i can spray dye it but that would give it the texture of sand paper, i do plan to spray the sunroof panels to match, may spray the visors to match, haven't decided.
the wrinkles seen in the fresh pics are gone the next day
