Results 1 to 2 of 2
Thread: DIY Hydraulic brake servo booster, 10 piece repair kit, e24,e28,e23,e32,(735 only)
    Nov 2012
    Default DIY brake servo booster repair kit and rebuild service
    Hi Forum Members,
    EDIT: 2-8-13, I have made some recent changes in the DIY repair kit and rebuild service.
    Please refer to my DIY link.
    https://picasaweb.google.com/1135658...KnZ_Z7f6JrUyQE#
    For the following cars, with Hydraulic brake servo booster, and ABS.
    e24, 628,633,635,m635,m6,L6;
    e28, 525,528,533,536,m535,m5;
    e23, 728,730,732,733,735,745;
    e32
    , 730,735,750;
    I now have of the interior components for the rebuild of the brake servo booster. I installed these new parts into my M6 over the weekend. The road test was a success, all of the parts work as they should!
    The new up-graded kit includes the 6 internal rubber o-rings, a 9.5mm I.D. shaft seal. 7 pieces total.
    I have also up-graded the Picasa Link, I took more photos and added more captions to show the correct method that I used in the assembly of the booster.
    Here this the link to the DIY, and the current pricing, and the step by step instruction, of the booster repair.
    Please read the captions at the bottom of each photo.
    https://picasaweb.google.com/1135658...nZ_Z7f6JrUyQE#
    Dremal hobby tool at Home Depot $69.00 this is a must have tool to do this job correctly! The Dremal is variable speed.
    Rotary Tool Kit-3000-1/25H at The Home Depot
    EDIT: 12-12-12
    This Do It Yourself (DIY) is to re-build the Brake Servo Booster # 34331156925. For the e23,e24,e28,e32-735.
    On the e23 it is part # 34331152825
    The e23,e24,e28,e32 735 all of the 7 piece interior repair kit are identical, for both part numbers.
    On the e32 750 there is a different part # 34331161772.
    It has a shaft seal to replace the standard o-ring at the firewall end,
    and this shaft seal is more expensive than the o-ring.
    I recently rebuilt another hydraulic brake servo booster, and I was amazed at how the rubber o-rings were deformed. They are now an oblong shape. The large o-ring 38.0mm x 3.0mm, at the front of the booster. It now measures 2.55mm high instead of 3mm. And is 3.28mm thick, were it should be again be 3.0mm. And it is noticeably more brittle. The smallest o-ring was brittle and it broke when removed.
    BOOSTER REBUILD SERVICE
    I am now offering to rebuild your booster for you, using my 6 piece repair kit.
    The price is $80.00 + shipping back to you. Cont USA only, USD.
    If you send me your address, I can give an accurate shipping quote.
    Via FedEx Ground home delivery, with tracking.
    I will then send you my address.
    Just send your booster to me, with a $ check. You insure for $190.00
    PayPal add 4%
    On the e32 750, please refer to my DIY link.
    REBUILD SERVICE WITH CORE
    I also have a couple of spare rebuilt boosters, and I can send one to you.
    And you return your old core to me, return shipping on you.
    Price is $80.00 + ship + $75.00 core. Cont USA only, USD.
    When the core is returned, the Core deposit will be refunded via PayPal.
    PayPal add 4%.
    On your e32 750, please refer to my DIY link.
    Send me an e-mail so we can get started, jay_c_stratton@hotmail.com
Size:  87.3 KBName:  PICT0002.jpg
  1. hydraulic brake booster unit replacement E32 750
    Last Post: 01-02-2015, 07:31 AM
  2. Replies: 2
    Last Post: 04-22-2013, 12:19 AM
  3. Hydraulic Brake Booster Front Seal (O-Ring)
    Last Post: 05-10-2009, 10:06 PM
  4. Brake Booster (Servo) Leak - E34 540
    By black_bird_blue in forum 5 Series BMW
    Last Post: 04-16-2007, 11:32 AM
  5. rebuild hydraulic brake booster for only $120
    Last Post: 12-29-2006, 12:57 AM
