I have an 09/89. Mine isn't on the oil canister, it's toward the back on the head...
RealOEM part 16
It's a bugger to get to...
RealOEM part 16
Ken, from Melbourne AUS.
'89 535iA with a 5 speed swap.
Found it! Your right, at the back of the head underneath the coolant tank and wiring harness. Looks like I need to remove the tank to get easy access. Also, I notice the black casing is broken, and it only has 1 green wire. I'm assuming the message comes on when the car is started and shut off, because there is no oil in the head at the first 5 seconds the car is started then when shut off? It only comes on for about 5 seconds when I start the car, then about 20seconds when I shut it off. car built 11/88.
Its just the same old same old problem thats been discussed a zillion times before.. the check valve in the oil filter canister is allowing the oil in the filter to drain down into the crankcase when you shut the engine off and it sits for a long period of time. On startup there isn't any oil pressure getting to the sender until the oil canister fills up and then goes to the rest of the system. When that check valve goes back you have to replace the canister since its a part of it. A few people on here have attempted to repair the check valve and Bruno and some others have made a bypass plate to allow external filters with built in check valves. On yours i would just check the Orings on the threaded bolt in the center of the canister lid to make sure they are good and then inspect the check valve in the bottom of the canister.... Its possible its your oil pressure switch but its pretty unlikely.
