As you said there are internal bumpstops, so no adjustments can be made. YOu cannot use the stock foam bumpstops. There could be several reasons why you have this feeling. First, you are not use to it. Second, give the suspension a month to settle in. Third, you said there might be some mismatched issue, perhaps rear steering and that signifies perhaps bad pitman arms (dog bones)....even if you recently replaced them, check to see if the boots are bad. Fourth, could be a combination of sorts. Good luck with finding the reason.Originally Posted by repenttokyo
