well it must be worth a shot....were they blocked???
In spite of my best efforts I ended up breaking one of those minute wires to the valve in the Heater valve assembly when taking it apart to see if it was clogged and if i could clean it. It seemed perfectly clean everwhere but i broke one of the small wires coming from the power pins. They are extremely fine and very short . Has anyone ever repaired such a break? I have a soldering iron and solder but there's really no room to work with . Are they junk now?
1995 540i Manual build 1/95
Have you got a photo? It sounds as if you're talking about solenoid wiring - if so then just solder it to the terminal - you might need some extra wire to bridge the gap.
If i try it i'll take pictures.. The thing i dread is breathing the lead fumes... I'm already damaged enough,lol.Originally Posted by Paul in NZ
Yes the Solenoid wiring. Its under a little plastic cover at the base of the solenoids. I may give it a shot when I know I have enough time to give to it. It just looked like the wire was so fine I couldn't imagine a drop of solder adhering to it and also thought the wire itself might begin to melt. I might try taking a strand from some speaker cable i have and just replace the wire entirelyOriginally Posted by pingu
lead free solder is widely available.
I usually just time my breaths anyway, soldering such a small wire shouldn't produce too much byproduct.
I think it's about time for a photo! In the meantime, I suspect you'll be able to scrape of the insulation off the last few millimetres of the wire so that you've got a reasonable length to solder onto. On some types of wire, a (hot!) soldering iron will burn through the insulation. But don't breath in the fumes from the wire.
The Unit is installed in the car. I don't have a spare. When i take it out again I'll snap pix. All the solenoid wires are bare. I think if i try soldering i'd have better luck removing the two halfs and soldering in an entire new wire.Originally Posted by pingu
usually they break here where they go into the valve,
plus more pics
