Results 1 to 10 of 16
Thread: E34 replacement wiper arm size (length)
    Feb 2005
    Penang, Malaysia
    Default E34 replacement wiper arm size (length)
    i'm looking to replace the OEM ones with Bosch Aerotwins.
    what should be the sizes for both driver & passenger arm (in terms of length in inches) that i should specify?
    is it 24 inches/24 inches (driver/passenger)?
    do you have a welding machine? One arm has to be cut and rewelded again in a different way, at least that is how it works on E32
    http://www.bimmerboard.com/forums/posts/349957/
    Marietta, GA
    You need 22" for both. 24" will be too long. As you can see in shogun's picture, the passenger side will not wrap around the bottom corner of the window. This does not affect its performance however.
    What is the difference between the AeroTwin wipers and the Icon wipers? They look almost identical.
    Feb 2005
    Penang, Malaysia
    mine is a RHD (like UK cars) - so it should be 24" LH (passenger) & 22 " RH (driver)?
    Quote Originally Posted by bubba966
    You can run a pair of 22" blades, or a 22" blade on the LH side and a 24" blade on the RH side. But you can't run a pair of 24" blades as they're too long on the LH side.
    I've got the 22" LH and 24" RH setup (factory) on mine.
    Sep 2007
    Seattle, WA
    East Brunswick, New Jersey
    I just did this last week. 22"/24".
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Jan 2007
    Dayton Ohio
    Default Shogun will this work
    Shogun
    Will this work on my 1989 535i?
    K
    Jan 2007
    Dayton Ohio
    Which is 22" right or left side from back of the car?
    Sep 2007
    Seattle, WA
    Quote Originally Posted by Kibokojoe
    22" blade on the left side when in the car looking out of the windshield.
    Feb 2007
    I ordered a set of aero twins and found the drivers one didn't fit (RHD car) because of the reverse U so I sent them back. When I returned them the guy was surprised that they didn't fit as he'd sold to many e34 owners. Do all e34s have a reverse U or is it something to do with whether you have the speed sensitive pressure thing?
  1. wiper arm and blade replacement
    Last Post: 12-17-2007, 11:11 AM
  2. exact length of e34 520i salon car
    By Fraz06 in forum 5 Series BMW
    Last Post: 09-24-2007, 06:19 AM
  3. replacement of wiper mechanism- DIY info
    Last Post: 03-05-2006, 06:14 AM
  4. Right Wiper Size Please!!!air Filter?
    By GAGE308 in forum 5 Series BMW
    Last Post: 03-29-2005, 09:18 PM
  5. Custom Length Serpentine belt?
    Last Post: 01-10-2005, 04:05 PM
