Results 1 to 9 of 9
Thread: Short Shift Kit for 520
    Sep 2006
    Cottingley
    Default Short Shift Kit for 520
    Hi Everyone,
    Does anyone know if short shift kits are availabe for an E34 520i (1992). There's loads of play in my stock gear selector and want to replace it. Just wondered if it's better to replace with a new BMW unit or just replace with a short shift kit (if they're available). Seen them advertised for the M5 but not for the lowly 520!
    Cheers
    Neil
    PA
    Well its a 92 so its an M50B20, I'd guess that any 525i short shifter would fit too
    A lot of people use like Z3 shifters and schitt.
    illinois, USA
    i have a 535i with a short shift kit. it's great i love it. if i had to guess i'd say it's about a 50% throw reduction. a lot harder to shift, but it's worth it.
    Jan 2005
    Kelowna, B.C., Canada
    I installed a shifter from a Z8. Pretty much any BMW shifter will work. Check this link.
    http://www.unofficialbmw.com/e36/dri...ift_lever.html
    Nov 2004
    How is the throw and shifting effort for Z8 shifter you got ?. I have been considering this for some time. Concerned about the nocky feel and the greater effort. I guess using a shorter shift knob (aftermarket) and adding a 1 pound weight to the lower shift linkage help. Thats what I got. I have also wondered about the slight tilt if you don't bent the shifter level like Ron S suggested.
    Frisco, TX
    I just installed the short shift kit from understeer.com. It is harder to shift but I like it. I'm not sure if the UUC kit would be much better but it was almost $250 more.
    Jan 2005
    The Z8 shifter has the same bend as the stock shifter. The only difference is that it is shorter. It feels great, it isn't notchy at all and doesn't take any extra effort to shift. I read here that the Z3 shifter was a bit too notchy so I went with the Z8. For the price it was very worth it. BMA sells a kit thats put together with OEM parts for around $75, but I'm not sure which shifter they use. If I was in the US I would have just gone with that.
    Jul 2005
    New York
    you can go with a SSK or a z4/z8 ssk, and you can talk to Rob Levinson at UUC. google them, UUC Motorworks. Located in dirty jerzeeeeeeeeeeee, 908 area code represent.
    You're my hero.
    Jun 2006
    Fareham. UK
    Hartge, AC Schnitzer they all do short shifters. If play is too much check the small nylon washers for play too.
    BMW E39 528i SE 1999
    BMW E34 525iA SE 1992
    BMW E34 535i SE 1988
    BMW E28 525i
    BMW E24 628 CSi
    http://web.mac.com/johnstjohn1
    Don't tempt fate, slap it and then taunt it!!
  1. Short Shift in the 540?
    By Jehu in forum 5 Series BMW
    Last Post: 02-08-2008, 09:25 PM
  2. e30 m3 short shift on e34?
    By L11_XTC in forum 5 Series BMW
    Last Post: 09-29-2006, 01:49 PM
  3. Short shift kit
    By Ted K in forum 5 Series BMW
    Last Post: 12-02-2004, 06:17 PM
  4. whalen shift knob short shift combo - E39 2000
    By peffer in forum 5 Series BMW
    Last Post: 09-13-2004, 11:41 AM
