Results 1 to 4 of 4
Thread: Slightly OT. Serpentine Belt on 97 Caravan
    Boston, Ma
    Default Slightly OT. Serpentine Belt on 97 Caravan
    I have a 97 Dodge Caravan. And almost every time I go over a puddle, the serpentine belt falls off. It happens so often that it only takes me 2 minutes to get it back on in the dark. But never the less there is some reason why it is doing it. The Belt tension is tight and the belt is relatively new (maybe 7k miles on it). The tensioner seems to be working properly. The only thing that is wierd is that The tensioner almost doesnt move enough to get the belt back on, it is a struggle to push it on with it fulley swung. Any ideas on possible problems.
    Default Here you go but you may want to download it today because i'm
    not going to leave it up for more than a day or 2 Click here for the pdf file..
    On an offnote does anybody know why when i make a pdf file out of some
    bulletins they come out with the line drawings reversed like this one.. black equals white and white equals black on the original
    Quote Originally Posted by bjl4776
    Boston, Ma
    Wow, thanks. It looks like exactly the right thing. The only question I have is my motor is the 3.0l, not the 3.3 or 3.8, But the belt set-up is the same and it is the same exact problem, could it be the same thing?
    Aug 2004
    detroit
    97 most likly has a 3.3l, unless you have a lxi, or high luxery model, and also, im pretty sure that the intake gasket will say it right on there
  1. M50 Serpentine Belt Tensioner Tool . . .
    By gale in forum 5 Series BMW
    Last Post: 06-10-2007, 10:36 PM
  2. HELP!!! Serpentine Belt Routing 525TDS 1996 !!!HELP
    By zwarbyt in forum 5 Series BMW
    Last Post: 03-27-2007, 07:15 PM
  3. m50 serpentine belt replacement question
    By brick8 in forum 5 Series BMW
    Last Post: 12-04-2006, 07:34 AM
  4. Urgent: Need M50 belt diagram (serpentine)
    Last Post: 08-20-2005, 08:04 PM
  5. Custom Length Serpentine belt?
    Last Post: 01-10-2005, 04:05 PM
