Originally Posted by
Strap
is correct and the best location, it's the only solid Black wire in the plug ( i cant remeber the pin number but it is listed on this forum somewhere) you can test it with a DMM Not a test light!! set the meter to A/C voltage.
Also you can use a injector wire depending on the remote start your using.if it has 1 , 2 ,4 ,6 ,8 cylinder settings or tach learning . DIE all have tach learning so you can use either. 1 bit of advice 2 diodes or 2 relays for the parking lights , get them at the dash switch 2 grey wires right and left ( dont connect them together ) they will only flash outside the car not the instrument cluster.
Strap
