Results 1 to 10 of 18
Thread: Driver's side door will not unlock! Button seems stuck
    Default Driver's side door will not unlock! Button seems stuck
    The lock button on the driver's side door of one of my 1991 525i's won't budge using any normal methods. I can't pull it up when using considerable force, but not really giving it all of my strength for fear of breaking something. All of the other doors plus the trunk lock and unlock normally from all three of the key receptacles, including the one in the driver's door. However, nothing seems to budge the button on the door and I cannot figure out what to do to get it unlocked. I can't imagine that this can be an electrical problem. Is this simply a mechanical problem that I can resolve easily?
    Anybody have any ideas what it could be or how to get it unlocked? I am too large to crawl over the console very many times without getting chafed in uncomfortable places. :-)
    Dick Schneiders
    baton rouge, loserana
    usually when this happins the solonoid is seized and needs to be replaced, you gotta take the door panel off and play with it to tell for sure
    Benneton (United Colors of)
    Default from sean and yo-hawn's site.....
    Default there are also...
    other door lock concern procedures there in the menu, if that doesn't help.
    Default Winfred, will the door panel come off when the door is shut?
    Is there any way to "force" the door open to make working on this easier?
    Dick Schneiders
    getting the panel off with the door shut is a mother without killing the panel, i've never had to atack a front door, it's usually a rear door that's stuck so i am not sure if my usual plan will work, i break the black aluiminum trim around the handle off, then i can unbolt the handle push it inside the door and reach in through the hole and cut the white plastic end of the lock solonoid, then i can unlock the door and open. this is how i do a rear e34 door, this may not work on a front door
    Default Thanks, Winfred. That gives me a couple of options.
    I like that idea much better than taking a chance of ruining the panel.
    Dick Schneiders
    Default Winfred, I hate to bother you again with this, but
    when I started to work on the door locking problem this afternoon, I decided to try to fiddle with the key and lock a bit more before breaking out any trim pieces or trying to remove the door panel. To my surprise, after several minutes of no success, the drivers side door button lifted and the door unlocked! It didn't jump right up quickly, as it normally does, but lifted slowly and not all the way. But the door was unlocked. Last night, when this happened, I spent almost an hour trying to use the key and locks in every combination I could think of and it never budged.
    Now I have a different problem and different questions. Certainly this is a much better situation than previously, but I am not very comfortable with locking the door any more without knowing what is going on. Would you venture a guess as to whether I should still order a new solonoid and replace the old one, or if something else might be going on? Could it be that the solonoid has shifted, like the article Ryan referenced in this discussion, and I need to get in there and adjust it slightly? Or should I just ignore this situation and go ahead and lock the car and *hope* it never happens again? :-)
    I really prefer the last choice, as it means doing nothing, but I doubt that this was simply a fluke due to the position of the earth to the moon last night.
    Dick Schneiders
    Default Dick, If i was you id at least pull the door panel and look around in there
    i pulled my door panel, it's not hard...really.
    Default Thanks, Jeff, I appreciate the advice. I have
    never taken one out and it looked a bit daunting to me. However, since I was prepared to have to do this, I should go ahead and do it. Especially since now it will be much easier with the door open.
    Dick Schneiders
  1. Replies: 7
    Last Post: 08-03-2009, 07:28 PM
  2. Driver's side window stuck
    By InfernoM3 in forum 5 Series BMW
    Last Post: 11-15-2006, 02:51 AM
  3. How to unlock a stuck double-locked rear door?
    By nuclearfusion in forum 5 Series BMW
    Last Post: 08-07-2006, 09:51 PM
  4. Drivers side door wont unlock with key
    By Moondog in forum 5 Series BMW
    Last Post: 02-21-2006, 01:08 PM
  5. Driver's side door stuck closed... Help!
    By Spartacus in forum 3 Series BMW
    Last Post: 02-05-2006, 09:38 PM
