Because it does virtually nothing for an already well designed suspension
Hey, why does there seem to be so few options when it comes to a strut brace for an e34? It seems like the racing dynamics bar is the only one available. Why no sparco or AC, etc.? Anyways, anyone know why this is, if the racing dynamics bar is any good, or know where I can find other options?
David
A recent post:Originally Posted by dlee
http://www.bimmer.info/forum/showthread.php?t=8840
As I said in My post - they probably do something or else the ///M's wouldn't have had them installed from the factory.
Some agree, others disagree - hence the "forum" aspect.
As to why only RD is common, I suspect the market isn't there since it's a custom fab job. I think there are other brands, maybe Dinan, I think I saw one on ebay recently.
I have the RD bar and it is fine - nothing wrong with it but I've not tried anything else, nor done any real experimenting on how much good it does with or without the bar. If you really want one and can get one cheap - go for it!
Robin
72 Chevy K10
01 E39 M5
http://www.e30m3performance.com/myth...bar_theory.htm
Might want to read that. I haven't gone through the analysis myself to see if it holds water since I don't have the cash for one myself, but perhaps you could and write a book report for homework.
Hi,Originally Posted by dlee
If you want some real world data on whether or not a brace would do anything for your car then try this. Take some dental floss (everyone should have some around the house because they floss daily ) and tie one side to a door knob and the other to a pencil or your finger. Pull really hard and watch the floss snap noting the force required to snap it. Next, go out to your car and tie one one end of a string of floss to one shock tower (nut under the dust cover or one of the mounting nuts) and tension the floss very tightly with the other side on the opposite mount as if it were a strut brace. Go out and drive your favorite road, autocross course, and/or race course as sprited as you like. Periodically check the floss and see if it has snapped. If your chasis is flexing to a point where the floss breaks then you may benefit from a brace, if not then it is strictly for looks. I am willing to bet that very few people could get their E34 to snap the floss and none in a "legal" driving situation.
Good Luck,
Rory
<Insert list of modifcations or clever saying here>
As Robin pointed out, opinions vary but in the end, when you have gathered all the evidence about the function of a strut brace, you will be convinced that it does have a positive effect despite blurts to the contrary with nothing to back it up. ...and the post about the theory is icing on the cake. The author, however, could've taken his analysis a step further by including the effects of tire width on the forces exerted on the struts and such.
There are also benefits as far as prolonging the life of suspension components is concerned. Some say that alignment angles and spring rates are greatly maintained with a SB. The fact is, you get most out of a SB when you are really after peak suspension performance, like on the track.
Ditto from this end, get one if it's cheap.
ntxt
You can't compare the M3's to the E34. Take a look at the M5's.
TCD sells strut bars for the E34 as well as some trick turbo kits. You can see the pics of the bar when looking at their turbo kit pics.
http://www.turbochargingdynamics.com/tcd_catal.htm
http://www.bimmer.info/forum/showthr...53485#poststopOriginally Posted by dlee
