Results 1 to 10 of 11
Thread: fuel pressure regulator
    Jan 2005
    Default fuel pressure regulator
    I replaced the return hose on my fuel pressure regulator ('91 535i) this weekend, and I noticed something real funny. When I removed the hose there was no fuel in it. None. Nothing.
    Is this an idication that my regulator has locked up not allowing any return? Please advise.
    Default Just curious. Why did you replace the hose?
    Javier
    Jan 2005
    Default maintenance
    Aug 2004
    Dubai
    Well I've been suffering from this thing before 3 months ... this regulator is very sensitive, if u have no gas at all that means 2 things; either ur regulator valve is stuck and u should have a very bad idle with black smoke, or ur fuel pump is warn out and lost its pressure. I think for the 535i it should have 3.0 bars valve. so u can check the pressure with a meter and then most probably the valve is done. also check the air hose if its cracked then it will retain the valve closed. but still the fuel pump should be powerful enough to squeeze the fuel out of the valve. hope that would help
    Jan 2005
    Thanks for the response. The idle in my 535i is real rough but with no black smoke. I have not been able to find any vacuum leaks or any other cause for the rough idle. The fuel return hose I replaced had a kink in it. I'm not sure fuel could could have gone through it. I replaced the question-mark-shaped hose with regular fuel injection hose until I can order the proper molded hose.
    Where is the best place to hook up a pressure gauge on this fuel system?
    Default On the supply line right by the return line near the firewall where you replaced the
    return. You'll have to use a T fitting to put the fuel pressure gauge inline
    Quote Originally Posted by duckloads
    Aug 2004
    Dubai
    Well without too much investigation u can try one thing, if u can full throttle the engine then just replace the regulator valve and smile!! but don’t use any other air hoses than the BMW ones or same diameter at least. one stupid tech replaced it with the merc. plastic ones and it was causing the engine to idle roughly!! as the e30 engine is so sensitive to air leaks !! good luck I hope this will solve ur prob.
    LA, California
    Default vacuum hose
    How do you replace the vacuum hose on the other end of the fuel pressure regulator. Mine is all dry and cracking?
    Two things:
    - The vacuum hose on the cylinder bank side of the FPR is an easy thing to replace. I did it a few weeks ago. Got a length of the PVC hose from Patrick (check the ETK) and replaced it. The only questionably difficult part is reaching the nipple on the intake where it connects. Mine was cracked to all hell and I had to use a pair of needlenose pliers to remove the bits and pieces. A 5 minute job.
    If the FPR issue is still in play: I don't think you're supposed to have a lot of fuel in the question mark shaped tube. Mine was "wet" but not filled with stuff.
    best, whit
    LA, California
    Quote Originally Posted by lowell
    Two things:
    best, whit
    Do i need to replace the nipple piece also? I don't want to pull out the hose and find out that I need this part also? going to BMA on sat to pickup the items.
  1. Fuel Pressure Regulator...
    Last Post: 04-05-2008, 06:36 AM
  2. Fuel Pressure Regulator - Installation ?
    By BIGRED in forum 5 Series BMW
    Last Post: 07-11-2007, 12:18 PM
  3. HELP! can't get fuel pressure regulator out of fuel rail....
    Last Post: 01-21-2007, 09:26 PM
  4. Fuel Pressure Regulator DIY?
    By InfernoM3 in forum 5 Series BMW
    Last Post: 04-15-2005, 05:16 PM
  5. Question re: fuel pressure regulator
    By phildg2000 in forum 5 Series BMW
    Last Post: 07-06-2004, 07:56 PM
