Results 1 to 7 of 7
Thread: 540i engine
    Jan 2005
    Default 540i engine
    hi there .... when I push the brake pedal to stop the engine turn off ignition what shall I do ?? is an error in the brake system or in the engine ..
    Is your fitted with a manual transmission or automatic? Do you have any trouble starting the car? I had a similar problem with a failing battery, as it was not accepting a charge from the alt.
    A bit more information would probably be helpful.
    '94 530i 5-speed. The work begins...
    CT
    wha? syntax error
    King Of NYC
    umm your saying the engine runs on after you shut the key off?
    baton rouge, loserana
    i think it dies when he hits the brakes and or stops, that's my guess
    ok its the clutch if its a manual trans or the torque converter if its an automatic trans.
    damn were good even when we cant read it!
    Nashville, TN
    Five posts trying to figure out what a guy wrote.... what's good about that
    Derek A.
    90 535i 5 Speed - Style 5 17"
  1. Where is the engine ground strap? 540i
    By Tiger in forum 5 Series BMW
    Last Post: 04-02-2010, 07:10 PM
  2. :: e39 540i... engine bay.
    By Barney Paull-Edwards in forum 5 Series BMW
    Last Post: 11-24-2007, 11:22 PM
  3. 540i Engine Shudder/Vibrations
    By chiefcorey in forum 5 Series BMW
    Last Post: 06-27-2007, 08:03 PM
  4. 540i engine mounts.
    By mattyb in forum 5 Series BMW
    Last Post: 08-19-2005, 01:32 AM
  5. 95 540i engine tick
    By Klaus Schuller in forum 5 Series BMW
    Last Post: 06-01-2004, 01:06 PM
