Anyone replaced ALL hoses?
My car, is 10 years old and I do not believe any hose has ever been replaced. Of course, nothing looks bad or leaks. However, I am of the the opinion I should replace them all. Of course some of the hoses are not visible or even touchable. If you look at the ETK, there are some rather "unique" looking hoses involving the secondary water pump and I think involving heating the throttle body area. It just looks rather difficult and expensive even if you do it DIY.
TIA
Originally Posted by
pundit
I just arrived home tonight (45 mins before posting this thread) and as I pulled into the drive I could smell steam. Anyway I pulled the bonnet and realised that the short 90 degree hose between water pump and thermostat housing had well & truly exploded! Aye carumba!
Fortunately it had just only occured as the temperature gauge had not even shifted above normal and the bonnet insulator was covered in water when I opened the bonnet. In fact the hose appears to have expired just as I stopped in the drive. The low coolant level warning didn't occur until after I switched the motor off & inspected the engine before briefly restarting it to check for anything abnormal.
Apart from the smell of coolant still evaporating off the motor nothing smelt 'terminally' hot and overcooked. Believe it or not I just did a coolant flush yesterday to prepare for a coolant change and had ordered that very hose and a new thermostat today - which will be delivered tomorrow. Now I'm going to order the rest of the hoses as well. Lucky I still have my Toyota van, so I can get to work tomorrow.
A word of advice for anyone buying a 2nd hand vehicle. If you aren't absolutely certain that all hoses, thermostat, belts etc. have either recently been replaced, or are in good condition (not always easy to determine with some hoses & of course the thermostat) then 'bite the bullet' and replace them. Cause you'll definately have to after you've forked out $1000+ to fix the damage one $10.00 hose can cause!
