Originally Posted by
lorcet10s
Also the temperature pops up on the OBDisplay for no reason at all. If any of you gear heads or long time e34 owners have had this problem or can offer a suggestion it would be greatly appriciated.
Lorcet10s
Not sure about your other problems, but I'm going to make a psychic guess here - Evey time the temp "pops us for no reason" it just happens to be 38 degrees F. or colder. Right?
As for the LKM, I'd take a close look under a magnifying glass at the solder joints. Wiggle the relays while inspecting the solder joints on the other side. It should be visable this way if you do have dry solder joints.
1990 535i 5-sp., except for 16" M-Contours, cd deck, and clear corners, completely stock. 226k and running strong
