Results 1 to 10 of 16
Thread: Found the cause of my oil consumption.
    PA
    Default Found the cause of my oil consumption.
    1992 525i:
    So i took my engine cover off and pulled my coil packs for grins and to my dismay I found cylinder 2 and 5 having oil in the plug holes. Cylinder 6 has a yellow/brown residue as if oil had been dripping from the Valve Cover and down into the plug holes. There was no sitting oil in #6 but there was in #2 and #5, #2 being the worst. I am hoping that (since my coils are still ok) there is no escalated problem and replacing the valve cover will remedy this?
    Secondly, every now and then, I will very quickly blip the throttle from idle (to hear the motor sound) or when rev matching and sometimes I will get a "POP" from just infront of the fire wall. It sounds like a backfird, only its coming from up front. Could this be the sudden burn of the oil thats in the spark plug holes? If not, what the heck is this sudden firing sound, it almost sounds like a miss but all my coils and (to my knowledge) plugs are good. Coils were replaced but 15,000 miles ago (with Bosch). I didn't want to remove my plugs, knowing that oil would fall down into the combustion chamber and I am not sure how ideal that would be. Can anyone give me information on what i need to replace, and part numbers for the gaskets/o-rings? I can't find them in my ETK. I have a 1992 525i 5 Speed (build is 9/91).
    Hi Jon,
    Doesn't sound too bad...but I would check the spark plugs regardless. Simply take some paper towel and soak up residual oil from the valve cover around each plug prior to removal. Any oil after that, that falls into the plug hole upon spark plug removal is not an issue. Your popping may be a loose spark plug and if left unattended could lead to a bigger problem.
    HTH,
    George
    PA
    Quote Originally Posted by George M
    Hi Jon,
    HTH,
    George
    I am going to do as you say. Any idea on part numbers for the full gasket replacement kit?
    Default George, it is possible that the misfire could...
    be due to the oil in the spark plug well but it depends how dirty the oil is. If it hasn't been changed for a while, oil becomes somewhat electrically conductive with age.
    Hector
    Hi Jon,
    HTH,
    George
    Phx AZ
    Default Yeah if there is metal or dirt in the oil...
    If there is metal or dirt in the oil, it will definitely conduct. Afterall, this is why we change our oil, it becomes contaminated. Even water is an insulator as long as it is pure. It is the minerals that cause water to conduct electricity...
    Quote Originally Posted by Hector
    Hector
    PA
    Hector
    Hector,
    I consumed 1 qt. of oil in about 700 miles. switched from 10w30 to 15w50 in a dire attempt to save my oil. Motor oil is about 1000 miles old, barely used (synthetic). I think its just a sudden burning of the oil from the spark plug hole... but im not sure. This nose will happen maybe one time ever 3 days. The first time it happened, I had the throttle in somewhat while starting the car.
    Benneton (United Colors of)
    Default if y0ou're having trouble....
    finding stuff in ETK, suggest trying graphical search. i got this quickest by using-->graphical search-->engine longblock picture-->scrolling down to the picture of the cylinder head cover. dan d did a writeup...methinks that just asking for it from bma would yield you a good result, dan says there's a pcv/recirculator type oring likely to break that's not included in the kit if yer taking the cover off....i personally didn't have a problem with such an item.
    Phx AZ
    Default Where do you get the ETK SW? ebay?
    Default check your PM queue
    jason s
    Ryan, how did you access that graphic interface? Is it available to the general public? If so, I am very interested and would be very appreciative.
  1. OT:X5 Oil Consumption
    By Vanguard in forum 5 Series BMW
    Last Post: 08-16-2007, 04:02 PM
  2. gas consumption of bmw 520
    By dennyg in forum 5 Series BMW
    Last Post: 03-11-2007, 02:28 PM
  3. OBC Consumption
    By les741 in forum 5 Series BMW
    Last Post: 03-07-2006, 03:52 PM
  4. Oil consumption M52
    By bcorovic in forum 3 Series BMW
    Last Post: 01-02-2006, 10:31 AM
  5. Oil Consumption
    By spitfire in forum 5 Series BMW
    Last Post: 07-05-2004, 01:06 PM
