Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: 17" Tire Size on E34 (???'s)
    Jan 2005
    Ashland, Oregon
    Default 17" Tire Size on E34 (???'s)
    For those of you with 17's on your E34, what size/profile of tire do you recommend?
    I just aquired a set of 17x8 Racing Dynamics RGS chrome...supposed to be the real ones, I'll verify when they arrive. But I don't think the knock off companies make a 17x8 RGS wheel in chrome for the E34.
    Either way, they're currently wrapped in 215/45s... that seemed a bit narrow to me, but I'm new to the scene.
    opinions?
    -B
    Denver, CO
    I'm running 235/45 Yoko AVS Db's on my 17X8 t-stars -I like them and they seem to work great.
    Check Bruno's site for more info on wheel/tire specs: http://www.bmwe34.net/e34main/upgrad...ls_upgrade.htm
    Jan 2005
    Ashland, Oregon
    Quote Originally Posted by Patrick
    that sounds like an appropriate size to me... anyone do a staggered set up... 255 in back 235 in front?
    Jan 2005
    Sicily
    I run 235/45/17...very nice
    Yorktown, VA
    I do a staggered setup on mine. 235/45/17 front and 255/40/17 rear. I like the look although I've heard this setup produces more understeer than some folks like. But you have to push pretty hard to get there. I'm not sure if you can run this setup with all four wheels the same size though. Anyone?
    zmuff--1989 535i 5-speed--17" E39 Style 32's--JC chip--UUC Short Shift--
    --Racing Dynamics Springs & Sways--Bilsteins--Yorktown, VA
    umm Beez, I think you may be in a bad situation here. If your rims came mounted with 215/45-17 tires they were either mounted to a 3 series BMW or the previous owner of these wheels is an absolute ASS. A 215/45-17 tire doesn't have the load bearing capabilities for a car as heavy as an E34 so I am very concerned you may have a wheel with the wrong offset. If I were you, I'd check the offset by contacting the previous owner and make sure it is for the big body cars (+15). If the offset is +38 you are not going to be able to use them without spacers AND THAT IS NOT WHAT YOU WANT. The offset is casted into the back of the rim usually in the form ET+38 or P+38 or E+38, with or without the + sign. Hope this helps..........and NO, you do not want to run anything less than a 235/45-17 front tire PERIOD, and to run a staggered set-up, you need staggered rim widths. Yours are all the same, 8" wide.
    Texas
    Quote Originally Posted by Beez540
    opinions?
    -B
    Toyo Proxies TS-1, 235/45/17 in the front on 17 x 8s and 255/40/17 in the rear on 17 x 9s.
    Apr 2004
    Dallas, TX
    I run Potenza RE950 235/45-17 on all 4 corners. Love 'em!
    ...Bill
    Default I got the Falken 512 ZIEX 235/45ZR17 and ....
    they feel great so far.
    Texas
    After reading your reply, I realized I hit the 4 instead of the 5. The actual rear tire size is 255/40/17.
    David
  1. Tire size ?
    By Herb in forum 5 Series BMW
    Last Post: 04-30-2007, 02:26 PM
  2. Tire Size?
    By wishihad50k in forum 5 Series BMW
    Last Post: 05-04-2005, 08:10 AM
  3. Tire Size for 15" rims
    By granit_silber in forum 5 Series BMW
    Last Post: 03-24-2005, 10:41 PM
  4. E36 17" rims, what tire size???
    By Bruno in forum 3 Series BMW
    Last Post: 06-08-2004, 04:04 PM
  5. Stock 15" tire size
    Last Post: 02-27-2004, 01:03 PM
