Results 1 to 2 of 2
Thread: Turn signal fix?
    Default Turn signal fix?
    Can anyone help me? I have an 89 535. I had the steering wheel off and I must have bumped the turn signal lever. So when I put the wheel back on the lever was in the up position. Now my turn signals won't shut off when I go around a turn. Any suggestions on how to fix this?
    Default Check the link here, i knew this was in the archive just took a while to find it...
    Quote Originally Posted by Jer
    Warren G's turn signal problem
    To add to this post if the turn signal is turned on to the left or right then the white tab seen sticks out and the wheel breaks it off when you install. When the signal is in the center position then that white tab retracts out of the way.
  1. turn signal
    By julian1966 in forum 5 Series BMW
    Last Post: 02-23-2008, 07:15 PM
  2. turn signal malfunction
    By MJR in forum 5 Series BMW
    Last Post: 02-18-2007, 05:38 AM
  3. Turn signal issue
    By qball in forum 5 Series BMW
    Last Post: 07-12-2004, 02:16 PM
