Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: srs airbag question.....
  1. #21
    Lexington, Kentucky
    Quote Originally Posted by upallnight View Post
    Find someone with Carsoft 6.5 and have him read the srs module. After he reads the module he can clear the fault. I just helped a fellow BMW owner clear the SRS fault on his 535I.
    done that-will not stay fixed
  2. #22
    Mar 2011
    Appleton, WI
    Mine flashes on and off for a few minutes after I start the car, and then just stays on. What does that mean?
    88 E30 325i Convert
    61,000 miles
    Cirrusblau
  3. #23
    Means you have a fault with the SRS system?
    Mar 2011
    Appleton, WI
    I wondered. My owners manual is printed in German only, and doesn't always translate to English well.
    88 E30 325i Convert
    61,000 miles
    Cirrusblau
  5. #25
    Jun 2005
    Cheshire, UK
    Quote Originally Posted by 6670charger View Post
    Google is your friend. Search for "e34 manual pdf" and download the english version. There are plenty of sites out there offering the manuals for free (copyright not withstanding...) Over 300,000 returns with that search term.
    1997 e39 523SEi touring.
  6. #26
    @6670charger
    in case you need a reset tool in Germany, I also have some on stock in Germany
    http://www.bimmernut.com/forum/swap-...-tool-new.html
    Note that you will not get a TUEV certificate in Germany if the airbag light does not function perfect. They are now checking that always, and the old trick with tape to cover the bulb is known to them of course, so they check if it goes on and then off.
  7. #27
    Jan 2012
    Default Same SRS gremlin
    Yup, Ive got the same issue with my SRS staying on for a few minutes after starting . I have a '95 540i which I just purchased with 130,000 miles, and just assumed this was normal, .......guess I was wrong!!
  1. need help with an airbag code...
    By jasper in forum 3 Series BMW
    Last Post: 10-30-2005, 11:39 PM
  2. Drivers side airbag question
    By mbogosia in forum 5 Series BMW
    Last Post: 10-22-2005, 09:08 PM
  3. Airbag light
    By dcbimmer in forum 5 Series BMW
    Last Post: 06-09-2004, 12:11 PM
