Results 1 to 5 of 5
Thread: e30 325e noise in rear...........
    SCHUYLKILL COUNTY, PA.
    Default e30 325e noise in rear...........
    i keep getting a noise in the rear of my 325e. it is a repetative knocking that corrisponds with the speed of the car. the drive shaft appears to be tight.
    could it be the differential? it has a l.s.d..
    thanks
    tim s.
    e30 rear noise makers, wheel bearings, shock mounts, sub frame bushings, loose control arm bushing bolts, endlink popped off of the sway bar, never seen in 9 years but have read about sway bar to body mounts ripped out
    Default the noise is to consistant with speed...........
    i have had loose items before, but this sound to consistant with speed & it is worse when i turn or when i ride against any gear. all i have to do it release the gas pedal & it makes the noise much louder. the drive shaft feels tight when i grab it, but there is about 1/2" of play in the center bearing. my mech. suggested it might be the gears in the differential.
    any suggestions before i start spending money on parts i might not need.
    thanks again
    tim s.
    id drain the diff oil into a clean pan and look for metal if you think it's the diff
    Default ok, i will try that.
    thanks
    tim s.
  1. Replies: 4
    Last Post: 11-24-2008, 09:21 AM
  2. Baffling rear noise, 540
    By jofusfarr in forum 5 Series BMW
    Last Post: 06-14-2008, 01:15 PM
  3. rear car noise
    Last Post: 04-08-2006, 01:01 PM
  4. rear noise
    By old bob in forum 5 Series BMW
    Last Post: 03-10-2005, 06:03 PM
  5. Rear noise
    By jsvizijr in forum 5 Series BMW
    Last Post: 10-04-2004, 09:39 PM
