Results 1 to 8 of 8
Thread: Is this normal 535 ? or has something gone wrong ?
    Nov 2004
    Middle England
    Default Is this normal 535 ? or has something gone wrong ?
    Hello I am still a 'new' BMW owner, so still finding out.
    1.
    My electric windows do not have what I call 'one click up-down' ... I have to keep my finger on the switch to make them go all way up or down.
    Other makes of car of similar age (1990) have had this, so ...
    Is this normal ? or has something gone wrong ?
    2.
    The OBC display lights up at night, but the buttons dont, so I cant see them to touch at night.
    Central NJ - USA
    only driver window has one touch.
    sun roof too.
    obc buttons - can't remeber if lit or not.
    enjoy =]
    Near San Francisco, CA, USA
    Default When I got my 535i, the one-touch feature on the
    driver's window and the sun roof did not work. This, and other marginal electrical problems were solved by servicing all fuse terminals and inline multipin connectors with Stabilant 22. www.stabilant.com Now, everything works correctly, the turn signal flashes faster, and the instrument lights are brighter.
    There are 3 light bulbs in the OBC. The one in the back is for the buttons. Guess you need to replace that one. I think there is a procedure on www.bmwe34.net
    Quote Originally Posted by zygoteer
    1.
    2.
    Jan 2005
    Not sure if I'm being a bit too basic here but the one touch on the drivers window and sunroof are a little different to some other makes (and some newer beemers) in that to get them to work you give them a quick jab instead of other cars who often have a soft touch for normal openings and a hard press for the one touch.
    Sunroof I often have to give it a second of pressing the button let it go then a quick jab stirs it into one touch action.
    Jan 2005
    quechee, vt
    is the one touch a switch type thing? could you replace the other 3 switchs with 3 "driver switchs" or is the motor and or control differnent also? Bill
    Nov 2004
    Middle England
    thanks everyone ...i will try the diffrent way to press it !
    and I have looked at the OBC lamp items .. seems like i have to remove radio to get to the OBC catches
    I will do that when i have some spare time on sunday
    Default "Bimmers,Bimmers,Bimmers"(nt)
    Will Ollison
    Default All my windows go down with one touch, ...
    only driver's go up. It's for a safety reason. Sunroof is like driver's window. It is not switch related, it's GM controled.
    Javier
  1. Suspension - Normal?
    Last Post: 05-07-2007, 02:35 AM
  2. Is this normal
    By indymdm in forum 5 Series BMW
    Last Post: 01-10-2007, 03:49 PM
  3. M50 has sludge ...normal?
    By fujioko in forum 5 Series BMW
    Last Post: 03-27-2006, 10:19 AM
  4. Normal rpm range?
    Last Post: 01-26-2006, 03:45 PM
  5. OT: whats so wrong with a normal turn signal stalk?
    By xphilter in forum 5 Series BMW
    Last Post: 09-20-2005, 03:23 PM
