only driver window has one touch.
sun roof too.
obc buttons - can't remeber if lit or not.
enjoy =]
Hello I am still a 'new' BMW owner, so still finding out.
1.
My electric windows do not have what I call 'one click up-down' ... I have to keep my finger on the switch to make them go all way up or down.
Other makes of car of similar age (1990) have had this, so ...
Is this normal ? or has something gone wrong ?
2.
The OBC display lights up at night, but the buttons dont, so I cant see them to touch at night.
sun roof too.
enjoy =]
driver's window and the sun roof did not work. This, and other marginal electrical problems were solved by servicing all fuse terminals and inline multipin connectors with Stabilant 22. www.stabilant.com Now, everything works correctly, the turn signal flashes faster, and the instrument lights are brighter.
There are 3 light bulbs in the OBC. The one in the back is for the buttons. Guess you need to replace that one. I think there is a procedure on www.bmwe34.net
Originally Posted by zygoteer
Not sure if I'm being a bit too basic here but the one touch on the drivers window and sunroof are a little different to some other makes (and some newer beemers) in that to get them to work you give them a quick jab instead of other cars who often have a soft touch for normal openings and a hard press for the one touch.
Sunroof I often have to give it a second of pressing the button let it go then a quick jab stirs it into one touch action.
is the one touch a switch type thing? could you replace the other 3 switchs with 3 "driver switchs" or is the motor and or control differnent also? Bill
thanks everyone ...i will try the diffrent way to press it !
and I have looked at the OBC lamp items .. seems like i have to remove radio to get to the OBC catches
I will do that when i have some spare time on sunday
Will Ollison
only driver's go up. It's for a safety reason. Sunroof is like driver's window. It is not switch related, it's GM controled.
Javier
