Thread: 535 runs lumpy when hot
    Jan 2005
    Default 535 runs lumpy when hot
    Hope you can help - recently the alternator belt on my 1988 E34 535 snapped and since fitting a new one I'm having problems when the engine reaches normal running temperature.
    Once the temperature gauge starts to read near the middle it starts running lumpily and in the end stalls. Its worst when it is at idle speeds and once it stalls it doesnt like restarting while still warm either - any clues??
    Would be surprised if the alternater belt change itself has caused the problem but could the jump starting have caused some trouble?
    Jan 2005
    is the alternator giving out enough power like 14.5 volts when running "might be worn and the reason the belt snapped in the first place", it could also be the battery failing to hold a good charge
    1989 e34 520i se, red, mint condition (original)
    pro mechanic "all cars"
    Central NJ - USA
    battery is out of the equation when the car is running....
    Jan 2005
    Cheers for the suggestion
    After the belt snapped I did get the alternator reconditioned and when it stalled after fitting the new belt and alternator I called out the AA and they tested the power at the battery. Reading was about 13 or so if I remember rightly - which he said was OK.
    Also the dashboard battery light doesnt come on when its running lumpily so I had thought that this meant that the alternator is functioning as it should
    Jan 2005
    so alt and battery ok, next is idle control valve/rotary idle valve (clean it out) resistance between terminals should be aprox 40 ohms on terminal 1&3 and 20 ohms on terminals 2&3-2&1.
    check for air leaks on vacuum pipes and clean the maf sensor
    Kingston, Ontario, Canada
    Potentially in line with other recent threads on M30 valves, when was the last time you adjusted the valve lash. My motorcycle ran very lumpy in the last days of its stretched valves, before I had to replace the valves. The shims (moto eqvt. of adjusting rocker arms) were already at their thinnest accept. but when the engine warmed up and the valve stem expanded, the valves were no fully seating.
    Just a thought...
    1995 540i/6 Sport Pkg w/E.A.T. chip and Nikasil injection Duey's Gallery
  1. This could get rid of your rough lumpy idle!!!!
    Last Post: 05-05-2008, 05:44 PM
  2. tds lumpy idle
    By mystic_525_tds in forum 5 Series BMW
    Last Post: 05-05-2008, 05:39 AM
  3. 525 TDS - idle lumpy when warm/hot
    By Nickhlx in forum 5 Series BMW
    Last Post: 04-16-2005, 02:51 PM
  4. Lumpy idle - E34 V8
    By myblack540i in forum 5 Series BMW
    Last Post: 12-27-2004, 05:26 PM
  5. 540i - lumpy idle!!
    By 95-540iLE in forum 5 Series BMW
    Last Post: 11-01-2004, 11:58 PM
