i do know that if you wire them in parallel your ohmage will drop to 2.. and that will be bad for the amp if it's not powerful enough to run it.. so be careful. i do know that if you run the channel into a crossover, and then have two speakers run off that you will be ok as far as the amp is concerned.. maybe go that way?
what kind of set up are you running?
