Results 1 to 10 of 12
Thread: "Check Control" error message on the display?
    Central NJ - USA
    Default "Check Control" error message on the display?
    so in teh 90 535ia i tried to clean out the a/c
    Klima-Cleaner is a high quality aqueous branded product which removes bacteria, fungi and other germs from airconditioning units without the need for disassembly. Together with the added odor neutralizers, its fungicidal and bactericidal agents combine to produce an extremely mild recipe with a broad spectrum of activity and high substantivity which will not irritate the mucous membranes. Any recommendations issued by the vehicle manufacturer regarding the cleaning of the air-conditioning system must be complied with.
    after i sprayed it in, i waited 20 min for the foam to finish its job, and
    as per instructions tried to start the car and turn the heat on full blast for
    30 minutes.
    the car didn't start though...the obc was flashing things at me.
    let it sit overnight, still doesn't start, obc shows - 37C when its 44F here
    and the display below the tach shows check control owners manual
    i disconected the battery to try and reset everything, so its sitting there now
    what do you think might have happened?
    Benneton (United Colors of)
    where did you spray that stuff? you are usually supposed to spray it into any "suctionable" area in the passenger footwell or into the air intake where the windshield wipers are.
    Central NJ - USA
    i sprayed it into the vents..central on teh dash and the side vents too
    when you say "central" do you mean the vents with the thumbwheels on them or the windshield defogger vents? most of that disinfectant stuff works by killing the germs in the evaporator area, not by acting locally at each vent. if there is a "backdraft" around the microfilter, you were likely supposed to shoot it in there and let the system distribute it with the ventilation ON. the air intake at the wipers also works ok for the same purpose. my hunch is that the liquid likely leaked into your OBC and caused some problem with the CODE function, causing you not to be able to start your car.
    Central NJ - USA
    okay i see.
    i sprayed it in everywhere...inside. nothing by the windshield wipers, all internal
    i thought it might be the obc code acting up cuz it wasn't getting sparked, just
    crankin....
    i'm looking for a obc removal guide too..
    Default It's funny, if my memory serves me well...
    OBC shows -37C if the temp. probe circuit is open (when removing front bumper, for example). May be it is only the connecting plug that got some chemical and is having bad connections.
    Javier
    Central NJ - USA
    perhaps? who knows what that foam did..
    guess i sprayed it into too many places.
    but my interior sure does smell nice =]
    Minus 37 degree C means that thing is dead.
    It does not go down any further.
    Usual culprit is the temperature sensor in the front or the wires connecting to there are oxydized or broken.
    Check that first.
    does the car start at this point?
    Default This link may help you unmoumt the OBC
  1. "Check Control" Message
    By vping in forum 5 Series BMW
    Last Post: 01-05-2009, 10:39 AM
  2. Fixed the "Low Beam" error message . . .
    By gale in forum 5 Series BMW
    Last Post: 03-04-2007, 11:07 PM
  3. Message Display "Check Coolant Level" & Leakage
    By rufryder in forum 5 Series BMW
    Last Post: 01-28-2007, 01:12 PM
  4. On the sevice display it reads "check control"
    By old bob in forum 5 Series BMW
    Last Post: 04-30-2005, 08:07 PM
  5. Installed HID's- Now "Low Beam" Error Message.....
    By Don McAdams in forum 5 Series BMW
    Last Post: 07-25-2004, 09:45 AM
