Results 1 to 5 of 5
Thread: Heater blower problem
    Mar 2004
    Sussex, UK
    Default Heater blower problem
    1992 525SE with a/c but not full climate control. Thanks to advice received here, I changed my filter and now get air in the cabin! Unfortunately, the fan is either off or on high - there's nothing from the intermediate switch positions.
    Any ideas?
    Thanks in anticipation,
    Rod
    battered but still going
    Default Resistor pack ...
    Blower resistor package (R11) may have the thermal potection open. See picture.
    Javier
    Mar 2004
    Sussex, UK
    Thanks Javier - how can I check resistor package, etc?
    Rod
    Aug 2004
    Argentina
    Default Picture below gives general ...
    instructions to remove resistor package, you should have a IHKR, so resistor should be in the LH Footwell, just up and right from the gas pedal, behind the carpet upper trimming. You are looking for component #5 from web link below.
    http://www.realoem.com/bmw/showparts...22&hg=64&fg=40
    Once removed, an Ohm meter should do it, just check proper continuity and ohm readings per the previous posted picture.
    Javier
  1. Heater blower
    By fsteyer in forum 5 Series BMW
    Last Post: 04-19-2007, 06:23 AM
  2. Heater blower fan
    By kuly in forum 5 Series BMW
    Last Post: 12-04-2006, 08:18 PM
  3. Blower / heater mystery
    By Morgenster in forum 5 Series BMW
    Last Post: 06-26-2006, 08:04 AM
  4. heater blower problem
    By macca in forum 5 Series BMW
    Last Post: 01-12-2005, 09:43 AM
