,Originally Posted by ryan roopnarine
that is the reason to suggest you to check the ground at pin 2 of the general module. This ground is distributed to all the transistor switches in the general module so to connect to ground the relays in relay module when requested. If the ground is poor, transistors will not turn on the relays, making them inoperable.
I'm sending the pdf drawing now.
Javier
2 , it grounds at x492 as seen here
[IMG][/IMG]Originally Posted by Javier
[IMG][/IMG][IMG][/IMG][IMG][/IMG]
Originally Posted by Bill R.
that's one of my problems, bill. nothing i have (bentley, otherwise) seems to say which fuses are what number. bentley has a list of circuits and amperage requirements, but im not seeing numbers for the underseat fuses. i also looked at the fuse holders, none of them seem to have numbers on them. it is the 2nd fuse from the left in the 30 ampere cluster.
and here is the link to the fuses...
Here is the link to the fuses
You are not supposed to have an F 32 fuse, and F 31 fuse is a 7.5 A fuse related to the Lock system motors. It feeds signals to General Module at pin 24 (Central Locking request passenger's side, as driver's side is fed by F 30), at pin 11 (Passenger's door locked), at pin 17 (Passenger's door unlocked, and Trunk unlocked, as Driver's door unlocked is fed by F 30), and at pin 23 (Trunk unlocked); it also feeds the Car phone transceiver, but guess you don't have one. If fuse 31 is blowing, you may have a short circuit in the General Module, at sensing inputs at pins 11 or 23.
The only 30 A fuses related to the General Module is the Fuse F 47 that feeds power to power windows, central locking motors, and the power protection relay coil, and Fuse F 44 that feeds power through the wiper relay to the wiper related relays in the Relay module. None of those should produce a massive shut down of General Module functions.
Please let us know precisely which fuse is blowing, so to be able to analyze your situation.
Javier
Finally! Someone responds inadvertently to what I was talking about....My alarm got screwed and the stealer replaced my general module to help recify this. He found that the DWA (? anyone know what/where this is?) was actually th culprit now...so I basically got screwed and $900 to disconnect the DWA and lose my alarm/keyless and my OBC. I could care less about my alarm system, but I can't live w/o my OBC! How could I find/change this part myself?
King Of NYC
it is located under the LH side of the rear seat. See picture (Look for N1).
