Yep.
Bret.
Will the front struts from a 92 525i fit on my fatass 89 525i?
Yep.
Bret.
are we talking the whole strut?.........or just the insert?..........the whole strut assembly will, however the inserts are not interchangable. 6/90 is the cut-off
I thought so. I think its the insert we're talking about not the part with the spring + the strut housing.Originally Posted by pmlmotorsports
If you have the entire strut including the strut bearing, it should bolt right in. If you have just the strut cartridge, you will need a new or newer strut bearing. Function is the same on both.
Mike Holbrook
Meridian, Idaho
