Results 1 to 5 of 5
Thread: FAST question about my replacement thermostat
    Default FAST question about my replacement thermostat
    doing water pump and thermostat right now. the replacement thermostate seems to be different then the one that was in the car. the one i pulled out has a drain type thing around the rim, the new one does not. the old one is a 75c and the new one is 87c.....
    what do i do? is it the correct one?
    Aug 2004
    Pittsburgh, PA
    Quote Originally Posted by RIPN RAY
    What type of vehicle do you have? Need specifics.
    opps sorry...i always forget that...
    93 525i m50 engine
    baton rouge, loserana
    drain type thing? little brass thingie with a small bit of metal rattling around inside of it? if so that a air bleed, drill about a 1/16" hole in the same position of the new thermostat and put it in the 12:00 position when you install it, this will serve the same purpose of burping the block
    Nov 2004
    Default if you keep forget'n...then create a signature by...
    93 525i m50 engine
    create a signature by clicking on the User CP link at the top left of the page...then click Edit Signature ...this will allow you to type your name, BMW model & model year and/or anything else you feel is pertinent). Then you'll never have to worry about forget'n to add it and when you ask questions that others may need to know what your model & model year is...it will be right there for them to give you a specific and precise answer.
    Merry Xmas!
    Q
    95 525iT / 97 740iL
  1. '90 535i : Thermostat Replacement leads to rattle?
    By hdaemon in forum 5 Series BMW
    Last Post: 12-27-2007, 02:14 AM
  2. OT: E46 thermostat replacement
    By guinness in forum 5 Series BMW
    Last Post: 02-18-2007, 12:44 PM
  3. thermostat replacement
    By semiretired in forum 5 Series BMW
    Last Post: 12-21-2006, 02:40 PM
  4. Engine Temperature, Thermostat Replacement
    By GoldenEagleFan in forum 5 Series BMW
    Last Post: 01-18-2006, 03:40 PM
  5. Front Shocks Question -- Need Help fast
    By kngpen in forum 5 Series BMW
    Last Post: 03-30-2004, 12:39 AM
