Personally i prefer NGK- BKR6EK, BMW uses those....Originally Posted by Interceptor
Hi all,
I can choose between NGK, Bosch and Denso Iridium for my 525i M50 - what do you suggest? What plugs are the best for performance, economy, etc.?
Thanks in advance!
plugs is plugs, NGK is good. Whatever you do dont use any of them so called high performance plugs or you will have problems.
BKR6EK NGK OR F7LDCR BOSCH will work fine
i use bosch
Where is the cheapest place to get them?Originally Posted by 632 Regal
95 BMW 525i black/black
-E.A.T. chip
-Blacked out grill and window trim
-17in AC replicas
-Blistein shocks & H&R springs
-Cadmium plated Brembo rotors
-Raybestos QS break pads
try a local foreign autoparts, might be able to special order them from a normal parts joint too. Dont ket them talk you into ant performance plugs cause they cant get the ones you need though. Mine have been kicking for 30k so fAr
in a pinch i've gotten bkr6ek's from hilo o-really when we are out of our own stock, can't remember $
an import parts dealer for the bosch. i think dealer got me for around $5.00ea.
tim s.
Check this out:Originally Posted by 632 Regal
http://www.denso.co.jp/PLUG/iridium-e/index.html
They do call themselves performance spark plugs, but after all, they are made in Japan, so it sounds promising - especially if you have a 4 valve per cylinder engine where spark shape and strength means a lot.
I used Denso Iridium spark plugs on my bike a few years ago and was entirely satisfied. My friend also put them in an E36 M52 320i a few months ago and says the lower rpm range has enhanced, idle is more even and that consumption is down a bit.
I want to know if any of you guys had any experience with them on your sharks.
I'm considering them because I ordered the EAT chip and want to maximize the performance it will give me - after all, performance chips do enhance ignition time, so I want to give my bimmer a chance to breathe with full capacity.
