Results 1 to 5 of 5
Thread: led doesn't work, help please?!
    Default led doesn't work, help please?!
    I' ve got a little problem with my 1989 525i. I have no indication from my right turn and high beam LED's. It's strange - because I've replaced the bulbs and they are working, but when instrument cluster is connected they're not. My indicator bulbs and high beams are also good.
    What else could it be?
    Default Here is something to try...
    Take out and inspect the instrument cluster board for cracked solder joints, or bad sockets. (You must've had the board out already from replacing the light bulbs, so I dont think you need the procedure.)
    Heat up and re-flow the solder connections for all of the lights that dont work, also it might be good to check the capacitors while you have it out.
    DanH
    1989 535iA 254k Miles
    1992 535iM 330k Miles
    Near San Francisco, CA, USA
    Default There is no practical way to check capacitors...
    They need to be replaced.
    Quote Originally Posted by DanH
    Default Thanks guys, but..?
    Thank you Gentelmen for a quick reply,
    My question is do I have to replace square caps too or jus the round ones?
    Could if possibly be something else? like a fuse or wire outside of the cluster?
    Quote Originally Posted by nariusb
    I did some soldering today. Concentrated on the area around the bulbs not working. Also cleaned everythign with alcohol and it's working like a charm now. Thanks to guys who helped.
  1. This will work in my car right?
    By Calico_NC in forum 5 Series BMW
    Last Post: 09-15-2007, 04:11 AM
  2. Too bad - didn't work out - M6
    Last Post: 04-29-2006, 09:03 PM
  3. Is there ANY way this could work with my car?
    By Jay 535i in forum 5 Series BMW
    Last Post: 11-30-2005, 05:02 PM
  4. will this obc work?
    By PABLO in forum 5 Series BMW
    Last Post: 09-05-2004, 05:39 PM
