Results 1 to 10 of 10
Thread: Thermostat installation question
    Aug 2004
    Pittsburgh, PA
    Default Thermostat installation question
    So I ordered some parts to install the new thermostat and I'm looking at the new housing and the two gaskets wondering if this is all I need.
    I have in my possesion Item 4(aluminum) , 5, 6 and 8
    Am I good to go with no gasket sealer or anything?
    Picture from here by entering the vin
    http://www.realoem.com/bmw/showparts...03&hg=11&fg=35
    Thanks!
    looks like you need # 7 too
    Nov 2004
    Default #7 or #8 gasket depends on model year/mfg date...
    if his 525i has a mfg date of 5/92-up...then all he needs is gasket #8. If its before that...then he needs #7. The manufacture date is located on a label on the drivers door jamb.
    Once again...this is an example when [b]specific[\b] car info isn't given like the model, year, manufacture date, or engine code...you can inadvertantly get incorrect info. In your favor, you did let us know it was a 525i...but that model has 3 different engines...the M20, M50, and M50tu...please remember that in the future. You must give us pertinent and complete info when asking a very specific question. Not all e34s are the same.
    Q
    95 525iT / 97 740iL
    Aug 2004
    Pittsburgh, PA
    Quote Originally Posted by Qsilver7
    Thank you
    I thought I entered that info in my profile to show up under my name?
    I'll be sure to include it in my post body next time.
    baton rouge, loserana
    you ether need a 6 and 7 or a 6 and 8 depending on the housing, a aluiminum bmw housing generally needs a 7 and the plastic needs a 8 and the common aftermarket housing needs a 8 which fits into a slot in the back of the housing like the plastic housing
    Aug 2004
    Pittsburgh, PA
    I changed it and all I needed was #6 and #8. Fingers a little scraped up but managed to change it without removing the fan. It gets to operating temperature now and the heat kicks, before it was only getting between 1/4 and 1/2 with luke warm heat.
    Bay Area, CA
    garlic. is your needle at the exact half point, or just a little over? i keep thinking mine is over the half point (by one needle width) and i need to bleed the system.
    www.KaRealtySF.com
    Aug 2004
    Pittsburgh, PA
    Its nuts on.
    the system burps it's self when the thermostat opens everytime you drive it, bleeding is only needed when the thermostat is air locked and will not receive the heat it needs to open. it depends on the gauge on where it sits, the big thing is once up to temp it doesn't move more then a needle width total
    Quote Originally Posted by liquidtiger720
    Default Another quality job thanks to Bimmer.info.com!
    Quote Originally Posted by Garlic Breath
    Its nuts on.
    i didnt even help on this one.
  1. hole in the thermostat question
    Last Post: 11-30-2009, 06:07 AM
  2. Question about thermostat gasket
    Last Post: 03-11-2008, 01:51 PM
  3. Question on M50 alu thermostat housing gasket
    By colo525i in forum 5 Series BMW
    Last Post: 12-30-2006, 08:46 AM
  4. Quick Thermostat question
    By guinness in forum 5 Series BMW
    Last Post: 07-31-2005, 05:57 PM
  5. FAST question about my replacement thermostat
    By RIPN RAY in forum 5 Series BMW
    Last Post: 12-25-2004, 06:24 PM
