Results 1 to 7 of 7
Thread: Testing Coils and plugs
    Malaysia
    Default Testing Coils and plugs
    Hi all,not much idea of how to test the coil connector to the plugs, could someone tell me how its done,i`m getting some hesitation on take off on my 94,525i. Sometime ago i noticed rubber rings on 2 different spark plugs and i suspect that the connector is not fitted well on some of the plugs...
    TIA/ jj
    Default if and when in doubt replace them...
    probably time anyways, cheap items.
    Malaysia
    Jeff, i agree with you on the replacing,but what bothers me with the coils to be exact is that they are rather new, when i take them off the spark plug, and put them back again i feel some of them make some type of resistance;ie, the spring like wire inside the boot its touching the spark perfectly, while,other coils fit on the spark with no resistance at all,as if the spring inside the boot is not in ful contact with the plug....
    i tried to do tests on my own but couldnt get any readings...you know....so that what made me wonder how this testing is made...in one earlier posts one thread mentioned that but forgot where to locate it...i think that posting was related to one of the friends in this forum who tested the MAS and gave good results,but turned out to be faulty later on...but don`t know who ????
    I appreciate your time and effort....
    Default I believe the plug boots are seperate of the coils,
    When I first got me car I had a miss...replaced the injectors, coils, plugs etc. Still had a miss and hesitation, did NOT want to see if the engine was Nikasil at that point. Found a huge leak in the intake hose, took care of the hesitation but the miss was still there, only at idle and more pronounced with the air on. Last thing I did was replaced the boots and the miss was gone...wasted a LOT of money before doing the boots.
    Malaysia
    yeah man thats what i mean, i have the 100% exact syndrom in my engine, the thing is am taking it step by step, am all on electrical now,found 2 faulty ignition wires coming from the ecu,too much resistance...i still bet on the coils not in full contact with some of the plugs but can`t determine which is which for that i wanted to test them to sort them out...
    Default JJ for the cost throw them away and get all new ones.
    after you figure out which 2 are bad and replace them, one month from now youll have a couple more giving you ****. Think of it like replacing 1 bad plug at a time.
    Mar 2004
    I'll be happy to pay shipping on any old or suspect coils so I can see if the following test works. Any volunteers?
    http://www.bimmer.info/forum/showthr...ghlight=ringer
    Paul Shovestul
  1. cold plugs or hot plugs, modified gap or stock gap...?
    By Boone.Msi in forum 5 Series BMW
    Last Post: 05-16-2007, 12:20 AM
  2. M50 520i Coils
    By courtster in forum 5 Series BMW
    Last Post: 08-18-2006, 06:28 AM
  3. Should my M60 igniton coils arc sometimes???
    By bimerguycw in forum 5 Series BMW
    Last Post: 01-24-2006, 01:37 PM
  4. Testing Ignition Coils
    By Kane in forum 5 Series BMW
    Last Post: 10-26-2004, 07:45 PM
