could someone please point me in the right direction for this info?
thanks
tim s.
on my 540i/a.
thanks
tim s.
thanks
tim s.
Idonno
havent found anything on that combo yet...anywhere...lol
they list the bmw offset
http://www.leightyres.co.uk/catalog/fitment.php
tim s.
If you are running E-31 turbines which a few members have on this board up to a 245mm tire width...which is a bit too tight in front... you should be fine...and need no spacers. Believe the offset for the E-31 stock wheels is around 13mm or so and a bit wider than stock E-34 wheels so about right. A decent setup would be to run 235 all the way around.
HTH,
George
P.S. Tim that guide you link is pretty crude for BMW offsets...and not wheel specific which matters a lot.
http://www.kalach.easynet.be/bmw_wheels.htm
i am looking at style #9's.
thanks
tim s.
I believe the E31 wheels use the same bolt pattern as the E34. In fact, many 850i/850CSi guys run the M5 parallels. Stock wheel for the 850CSi is 17"x8" ET13 and 17"x9" ET19. Not sure if the #9 were 16" or 17"...if 16" they still probably have similar offsets to the 17" wheels (13mm front, 19mm rear).
Hope that helps...
Cheers,
Duey
1995 540i/6 Sport Pkg w/E.A.T. chip and Nikasil injection Duey's Gallery
I'm with George on this one, care is required...Leigh doesn't show my stock ET18/22 fitment on OEM #5's in their chart...Originally Posted by George M
They are a straight bolt on to the E34, no spacers required. The offset is an ET15 vs. the ET20 for the stock rims.
Biggest tire you can comfortably get is the 225/55/r16. Micah had some 245 fat daddys and didn't have good results.
I have the RD sways and the tires will rub the front bar when at full lock. I just try not to do this.
It's a nice rim if you can find a good set. Forged. Easy to clean. The 16" rim gives a nice ride. I have 2 sets I like 'em so much!
Cheers!
Jeff
Originally Posted by tim s
Bellevue WA
86 Porsche 951 - Track Toy
