Results 1 to 7 of 7
Thread: What causes a squeal from steering and s.wheel shake?
    NYC
    Default What causes a squeal from steering and s.wheel shake?
    When i turn the wheel full lock to the left i get a loud squeal and the steering wheel shakes. Is this as simple as the belt? or is a much larger problem about to rear is head? i gives me a pretty uneasy feeling that something might be wrong w/ my steering. any info is appreciated.
    Jason
    Miami Lakes, FL USA
    Default To me it sounds like.....
    ....and mind you I'm not the smartest wrench in this tool box....that you:
    A...Need to top off the power steering fluid bottle...
    or
    B...You have tires on the car that are a bit too wide and they rub against the body/fender/wheel well when you crank the wheel all the way.
    Just my 2cts. Hope this helps.
    Brian C.
    There is nothing worse than a brilliant image of a fuzzy concept. -
    .............Ansel Adams
    Default Simple, dont reef the wheel to the lock position.
    just my 2¢
    Default Agree with Jeff...
    The squeal and shake is caused by the ps system overpressurizing at full lock, or something like that. It's normal, but it's not a good thing, best to back off a bit immediately when it does that.
    Default yes, a good way to blow hoses and/or ruin the pump.
    Quote Originally Posted by George Davis
    NYC
    Default Its not only at full lock, but i cant help turning pretty far, i parallel park alot
    just my 2¢
    Mar 2004
    Toronto, Canada
    You should let your wife sit inside the car. I found that when I did that it stopped the squealing and shaking.
    01 740i sport
    92 535i
    92 525 touring
    88 325ic
  1. light braking/wheel shake??
    Last Post: 04-14-2007, 10:46 AM
  2. Steering Wheel Shake (limited speed range)
    By SnakeyesTx in forum 5 Series BMW
    Last Post: 07-14-2006, 12:10 PM
  3. steering shake at 60mph
    By stix125 in forum 5 Series BMW
    Last Post: 04-25-2006, 03:27 AM
  4. Shake between 55 - 60 mph but not from steering wheel.
    Last Post: 05-27-2004, 11:35 PM
  5. Steering sqeak/squeal
    By TWKenny (formerly Ted) in forum 5 Series BMW
    Last Post: 02-20-2004, 10:31 AM
