Results 1 to 3 of 3
Thread: Radiator Hoses
    Default Radiator Hoses
    Need to replace my upper hose on my 95 530. Looked on BMA's website...they have an upper that says it goes from the radiator to the water pump and a lower that says the same thing.
    What do I need if I want to replace both hoses? Is that correct?
    TIA
    Central Iowa
    Default Both
    The upper and lower hoses both attach at the water pump on the V-8.
    Consider the 4 or 5 hoses at the driver's rear of the engine for the reservoir and heater control solenoids, auxilliary water pump too.
    If you have an automatic transmission, some models have two rear hoses that go down on either side of the back of the engine to a transmission heat exchanger block.
    Dave B.
    1994 540iA 180,000 miles on original Nikasil block.
    Nov 2004
    Default go to the BMW online parts database to get part #
    Quote Originally Posted by TWKenny (formerly Ted)
    TIA
    Then you can search BMA's website by the correct part number...then you'll know that you're ordering the correct part.
    All you need to do is enter the last 7 digits of your car's VIN then click the appropriate buttons to find the part numbers & exploded diagrams specific for your car.
    Click here: www.realoem.com/bmw
    Q
    95 525iT / 97 740iL
  1. Radiator and Hoses
    By Tiger in forum 5 Series BMW
    Last Post: 03-03-2008, 05:12 AM
  2. Question about bleeding and radiator hoses
    By granit_silber in forum 5 Series BMW
    Last Post: 10-28-2005, 06:02 PM
  3. Radiator Hoses
    By olsan100 in forum 5 Series BMW
    Last Post: 09-08-2005, 07:46 PM
  4. After Market radiator Hoses?
    By infinity5 in forum 5 Series BMW
    Last Post: 12-13-2004, 03:16 PM
