Results 1 to 3 of 3
Thread: Auto Transmission Mounts
    Jul 2004
    Perth, Western Australia
    Default Auto Transmission Mounts
    How easy is it to replace the rubber auto transmission mounts on a 1989 525. Can it be done without putting the car on a hoist ?? Also.... does any one have an indicator stalk with BC control that they are willing to ship to Perth Western Australia at a resonable price ???
    Thanks
    Garry
    Default Its very easy, if you have a floor jack and jackstands and a
    big block of wood. Just use the floor jack to raise the car high enough to work under and support it securely with jack stands, Then take a wide block of wood and place it between the transmission pan and the floor jack so that you can just raise the transmission a little bit without crushing or denting the pan, once you just take the load off the transmission , raising it maybe a half an inch, 12 millimeters,, then you unbolt the rear transmission mounts and install the new ones. Very easy and cheap.
    Quote Originally Posted by Mewsy
    Thanks
    Garry
    Jul 2004
    Default Thanks
    Thanks for that - I'll give it a try
  1. Replies: 9
    Last Post: 03-03-2011, 05:34 PM
  2. Replies: 3
    Last Post: 02-27-2009, 08:08 PM
  3. My UUC Track transmission mounts came!
    Last Post: 08-19-2005, 04:23 PM
  4. Help please!! Replacing transmission mounts
    By KurtM in forum 5 Series BMW
    Last Post: 10-03-2004, 03:10 PM
  5. Transmission mounts upgrade with OEM???
    By Bruno in forum 5 Series BMW
    Last Post: 04-13-2004, 10:45 PM
