Results 1 to 3 of 3
Thread: idle control valve cleaning question....
    Arizona
    Default idle control valve cleaning question....
    Can I clean the ICV without taking off the intake manifold since the ICV is located beneath it? Can I just spray some throttle body cleaner in through the throttle body ?
    baton rouge, loserana
    you really need to be able to spray the solvent into the valve to disolve and flush out the gummy deposits that interfear with it's operation
    Arizona
    Default ok...I cleaned it but i think it not working properly
    I looked up in the bentleys and it said that if I put a load on the system (such as turning on the AC) the rpm's should increase. I did that test but my rpm's decreased and then came back to normal. Does that mean that the icv is faulty? I had a hard time starting my car in the morning but when I eventually got it started it idled fine for a couple seconds and then died. Could my problem be the ICV? I checked the MAF, temp sensor, and throttle position switch.
  1. Idle Control Valve (ICV): Removal, Cleaning & Refitting.
    Last Post: 09-14-2012, 05:54 AM
  2. Anyone need/want an M50 idle control valve?
    Last Post: 01-21-2008, 10:19 AM
  3. Idle Control Valve
    By dcbimmer in forum 5 Series BMW
    Last Post: 09-22-2007, 04:19 PM
  4. idle control valve
    By bones in forum 5 Series BMW
    Last Post: 09-17-2007, 11:01 AM
  5. Idle Control Valve?
    By JMI in forum 5 Series BMW
    Last Post: 10-17-2006, 11:38 PM
