Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: 94 540i rough idle
    Nov 2004
    Default 94 540i rough idle
    Was wondering if any one can help me out. Just bought a 94 540I about 6 months ago. It has developed a rough Idle over the past few weeks. It started out idling rough at start up and then would idle smooth after about 2 to three minutes. It has gotten progressively worse. Now it idles rough at start up and continues to do so. Here is something else I have noticed about the situation. When I first start it it runs rough, if I shut it off right away and restart it will idle smooth for 30 seconds or so then go back to the rough Idle. After it warms up it runs alittle better but it is still rougher than i think it should be or when i first bought it.
    Willie
    Apr 2004
    Reston Va
    2 Questions first. 1) How many miles are on the car? 2) Did it just recently turn cold where you are?
    It sounds like 1 of 2 things. o2 Sensors or Intake Manifold Gasket. There is a Vacuum leak in the IMG that when the weather is cold gets exposed. The cold contracts the gasket opening up the leak. This causes rough running until the engine warms up and the heat expands the gasket closing the leak - allowing the engine computer adjust the engine to run normally. - JT
    Johntee540
    1994 540/6 Black - Tan - 199k
    Cardomain Site: http://www.cardomain.com/ride/737181/1
    Aug 2004
    Houston
    Default Nikasil engine block.
    Nikasil. you probably have a Nikasil engine block, as i do on my 530. ther's lots of info on this formum about Nikasil. To confirm this have it checked out by a bmw dealer or other shop. if you have less than 100,000 miles you may still qualify fora new engine, made of Alusil. some bmw dealers have a inventory of new blocks, i just priced one here in Houston, $3,800, just for the shortblock. good luck, if that's your probelm you have two options. 1) live with it, 2) replace the block. bob
    Default yep must be a bad block
    everyone on this board with Nikasil blocks have that same problem.
    I dont think so.
    Check for vacuum leaks from the air box to the intake, all the small hoses too.
    Nov 2004
    150K mi. It just turned cold but I noticed the problem before it did turn cold. The later of the problem has been going on since it got colder. The intake manifold gasket has been replaced recently. I was in the process of getting the O2 sensors to replace them. I will let you know when they come in if that was the problem. Thanks
    Willie
    Quote Originally Posted by Johntee540
    Default FYI the O2 sensors dont work when the engine is cold,
    thats why I say to thoroughly check for vacuum leaks first.
    Jul 2004
    Montreal, Canada
    when my 540 had rough idle for the first 2-3 minutes - then it would smooth out.... it was the pcv plate on the back of the intake manifold, now it is fine!
    ^°^ ><((({º>°°
    Apr 2004
    Reston Va
    Not everything points to Nikasil. Sheesh. This sounds more like a vacuum leak than anything else. Lets start the diagnosis cheap and work towards the expensive. - JT
    Johntee540
    Apr 2004
    Reston Va
    The rear of the intake Manifold is also a great hunting ground for Vacuum leaks. Also - all of your hoses are old and are biodegradeable. They will start to leak over time as well. At this point in the life of your car you will need to invest some time in making sure that there are no leaks whatsoever in the vacuum channels. Good luck - JT
    Johntee540
    Kingston, Ontario, Canada
    Quote Originally Posted by bpattan
    I'm wondering why is this (Nikasil to blame) often the default? A Nicky block (if he in fact has one) doesn't just suddenly turn in the space of a few weeks. Like John and Jeff note, vacuum problems are generally the blame, especially as the pliability of plastic/foam is reduced with the colder temperatures...I as well would check the rear vacuum valve...it's in here in the archives under "M60 vacuum plate, etc..."
    Cheers,
    Duey
    1995 540i/6 Sport Pkg w/E.A.T. chip and Nikasil injection Duey's Gallery
  1. 95 540i rough idle
    By h2oyo in forum 5 Series BMW
    Last Post: 09-29-2009, 08:03 AM
  2. rough idle on a 1995 540i
    By mislead in forum 5 Series BMW
    Last Post: 04-11-2008, 07:31 PM
  3. Rough Idle
    By hinchcliffe in forum 5 Series BMW
    Last Post: 08-27-2006, 10:12 PM
  4. Whats the definition or "rough idle" 540i\6sp
    By wmann in forum 5 Series BMW
    Last Post: 05-09-2005, 08:38 AM
  5. Rough Idle
    By Will308 in forum 5 Series BMW
    Last Post: 02-21-2004, 03:34 PM
