Results 1 to 10 of 10
Thread: Pentagonal Tool for Radio fitting/removal
    Nov 2004
    Powys, Wales UK
    Default Pentagonal Tool for Radio fitting/removal
    anyone know the part number? so i can order one from BMW or know where i can get one please.
    Cheers, Matt.
    Haynes - "Fitting is Reversal of Removal"
    Apr 2004
    NYC/Boston
    I just used an allen wrench.
    :shrug:
    actually, I needed a radio code for my car once, went to the dealer, they asked for a serial # off the radio, and just let me use their wrench... talk to any [cool] service adisor and the'll let you use it.
    Otherwise, I'm pretty sure that Bav Auto carries them.
    '91 535iM - SOLD
    '01 325iM - PP . SP . CWP . HK . SSK . ZHP springs . Konis . M3 strut bar . OEM sirius and aux . TMS sways
    Mar 2004
    Toronto, Canada
    Default I used allen wrench too...
    cheaper and easy
    Nov 2004
    Powys, Wales UK
    thanks, i tried removing with allen key and it just slipped, i look into getting one from Bav Auto, Matt.
    Dayton, Ohio
    I did mine last night with an allen wrench.... I had to try several different ones... and I put some pressure on the wrench when turning (I think that helped it grip)
    Former: 95-530iM
    Current: 99 GMC Seirra 1500
    Texas
    You can get it cheaper off eBay.
    Mar 2004
    Lawrence, KS
    Whatever the size is it seems to be in between any of the sizes included in any metric or standard allen wrench set. I just used the closest one that would fit and put a little downward pressure on it. If you're patient that will work, but be careful of stripping.
    Elm Grove Farm, NC
    you should be able to get it out with an allen wrench- the trick seems to be to put some diagonal force on the allen wrench to help keep it from slipping. What I mean is: put the wrench in the hole, then put some sideways pressure on the end of the wrench that you are holding, then turn the wrench. It should not be that tight, so once you get it loose, it should be easy to turn from there.
    I've used this method to remove about 20-30 BMW radios, never had one I could not get out...
    Bret.
    Default while we're talking stereo, how do you get the rear speaker covers off?
    Quote Originally Posted by A1BMW535iSport
    Cheers, Matt.
    Check out this link . . .Radio Removal Tool
    I bought Richard's tool for $5. He had it in my hands in less than a week.
    Cheers, Matt.
    current fleet - 96 328i (the wife's) | 93 525iT | 91 535iM | 85 635Csi
    gone but not forgotten - 75 2002 | 77 530i | 79 528i | 86 535i | 95 325is
  1. Replies: 5
    Last Post: 07-07-2006, 04:11 PM
  2. where can I get a wheel cap removal tool?
    By bbig119 in forum 5 Series BMW
    Last Post: 05-21-2006, 11:52 PM
  3. Radio rempving tool
    Last Post: 03-22-2006, 11:49 PM
  4. some info on OEM radio fitting to E34/32
    Last Post: 01-28-2005, 02:45 PM
  5. Where to get a tie-rod removal tool?
    By MO525 in forum 5 Series BMW
    Last Post: 03-30-2004, 05:00 PM
