Changed to my bottle cap winters and lo and behold dreaded shimmy surfaced I re balanced wheels to no avail so I tried rotation and still a shimmy. I have replaced thrust arms with 750 bushings in past,and rest of front end looks fine and other wheels and tires were fine so when I rotated front to back one side at a time found the shimmmy was minimized Man this is a pain in the a__.So I ended up with tires the way had them on last winter and shimmy was again worse...so I ended up taking the R front wheel off+ sanding mating surfaces and turning wheel 1/5 of a turn seemed to fit on easier guess what ? shimmy cured. So I thought how many of us are putting new parts on unnecessarily because of this or a mechanic that does not understand how fussy these cars are? Try all the simple things 1st my mechanic friend thought I was nuts but changed his tune when problem was cured so try, try ,try and you might luck out. Kuly 95 540Originally Posted by kentish
