Results 1 to 9 of 9
Thread: Blower speed selector switch - variable low speed works?
    Mar 2004
    Toronto, Canada
    Default Blower speed selector switch - variable low speed works?
    Hi guys,
    I just thought about this and thought I would ask you guys.
    On the fan speed selector switch there is the 1,2,3 etc on the right side (after 12:00 position).
    Between 8:00 & 12:00 position there is a marking suggesting that the fan speed should be graduated from 0 to level 1.
    When I have my fan switch there, the speed doesn't change at all and seems to run at the same speed as on selection 1.
    This isn't something worth taking the dash apart, but wondering if its just mine or everyone? If there is an easy fix... lets hear it!
    Thanks Rod
    Kingston, Ontario, Canada
    No, that's normal...from 0 to 1 is the fan on speed 1 and the air flaps open from a fully closed (0) to fully open (1)...from 2,3,4 the flapper valves are fully open.
    Try this...change the speed switch to different positions within the 0-1 zone and you'll hear the flapper valves hum as they cycle open and closed...
    Duey
    1995 540i/6 Sport Pkg w/E.A.T. chip and Nikasil injection Duey's Gallery
    Mar 2004
    Toronto, Canada
    I don't get it.
    The flaps? What do they do? The fan stays the same speed but the flaps block the air movement?
    In my case the air movement is the same no matter what position the fan is in, until you get past #1.
    R
    baton rouge, loserana
    i referr to that as the womens setting, that or all of the vents closed blower on full and ac on. dual zone is fun on road trips, my drivers side remains un touched for 600 miles or about 9.5 hours and moms side gets adjusted about every 10 minutes, the whole process is resumed the next days travel
    Default Those are for the fresh air flaps as pictured here.
    Quote Originally Posted by talltorontoguy
    Hi guys,
    Thanks Rod
    Nov 2004
    Washington
    Default Bill R...
    that's good information. I wondered about that too. I like the fast responses and information given on this forum. Keep up the good work. Thanks!
    Gainesville, FL
    So what happens if you have the air recirculation turned on? i suppose those flaps don't operate? although i certainly hear *very* noisey flaps whenever i turn the blower on
    Mar 2004
    Toronto, Canada
    I just don't want to get one of those "sudden unpleasant odors" that Bill talked about... ewwww
    Default And keep recirculating them!
  1. clutch switch on 5 speed conversion
    By mrbyoda in forum 5 Series BMW
    Last Post: 05-05-2008, 08:57 PM
  2. e34 4 speed auto VS 5 speed manual
    By adashio in forum 5 Series BMW
    Last Post: 05-24-2007, 10:35 AM
  3. Replies: 4
    Last Post: 01-04-2005, 08:32 PM
  4. Auto Climate Control: Blower only runs at full speed
    By Black530i in forum 5 Series BMW
    Last Post: 07-25-2004, 07:44 AM
  5. Replies: 3
    Last Post: 06-30-2004, 04:40 PM
