Results 1 to 7 of 7
Thread: Suspension torque spec?
    Default Suspension torque spec?
    Hi everybody.
    I haven't yet gotten my e34 bible (Bentley) in the mail and I need to torque up my new suspension.
    Can anyone give me the specs on the ball joint sides of the lower control arms, thrust arms, shock nuts (including the mounts), and all of the steering links? I got the loading requirements and specs on the arms off of Bruno's site, but I'm still in the dark on the other points.
    thanks...thanks very much.
    Lowell
    Oh yeah - and another question.
    When you tighten the control and thrust arms under load, do you tighten the BALL JOINT (seems kind of hard to do with the strut there) or the frame bolts (also seems hard to do given that you can't get an impact wrench in there, especially with the exhaust shielding on the pass side. Seems kind of ambiguous on Bruno's site...
    lowell.
    you only tighten the thrust & control arms under load.
    thrust/control arm ball joint is 67 lbs.
    not sure on the thrust/control frame mount, think its 95 lbs (guessin)
    Tampa Bay, Florida, USA
    From Bently:
    Control Arm Ball Joint to steering arm: 68 ft-lb
    Strut Housing to Steering Arm: 81 ft lb
    Control Arm to Crossmember: 57 ft-lb
    Thurst Arm Ball Joint to Steering Arm: 68 ft-lb
    Thrust Arm to connecting crossmember (PRELOADED): 94 ft-lb
    Just happened to have the Bently around.
    Also check out www.webshots.com and look at st100ray's album. He's got a couple of good shots on how to do the job. Actually there's a lot who've posted pics on this.
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
    Quote Originally Posted by MBXB
    From Bently:
    Don't you have to do the Control Arm to subframe under load as well? Just tring to make sure I get it all done right the first time...
    Upper control arms, also called thrust arms
    http://www.bmwe34.net/e34main/mainte.../upper_arm.htm
    Ramon
    Default Yes Lowell, the lower control as well as the thrust arm both
    have to be torqued under load at the subframe end of them.. the balljoint end doesn't matter if its loaded or not...
    Quote Originally Posted by lowell
  1. Steering idler arm to subframe torque spec?
    By paanta in forum 5 Series BMW
    Last Post: 02-27-2009, 12:56 PM
  2. Torque spec on knock sensor M60
    By bbig119 in forum 5 Series BMW
    Last Post: 12-23-2006, 11:01 PM
  3. Torque spec. for rear sway bar link
    By jhsmd666 in forum 5 Series BMW
    Last Post: 08-22-2005, 03:14 AM
  4. Replies: 9
    Last Post: 07-18-2005, 03:53 PM
  5. US spec vs. Euro spec cat converter
    By audiophile81 in forum 5 Series BMW
    Last Post: 04-29-2005, 12:15 PM
