Results 1 to 4 of 4
Thread: 1994 E34 battery location? (1994 525i Saloon).
    Default 1994 E34 battery location? (1994 525i Saloon).
    I'm guessing it's under the rear seat, but how do I get to it? Is there any other way to disconnect the power (eg fuse or relay)?
    I've just cleaned up all my ABS sensors and my light is still on so I'm trying to cancel the ABS memory (if it has one) and hope the light goes out...
    Thanks for any input!
    Near San Francisco, CA, USA
    Default Just pull UP on the rear seat, and it will come out.
    Then you can disconnect right at the battery terminal. Hopefully that will clear the light, or it's off to the specialist for you.
    Quote Originally Posted by UK E34
    on us cars the abs system self checks on every start, if theres a sensor problem usually the light doesn't come on till you start moving, bigger problems are usually what cause the light to come on and stay on
    inverness, scotland
    Grab The Front Of The Lower Rear Seat And Pull Upwords. The Battery Is On The O/side And Has A Plastic Cover On It.
  1. 1994 325 a/c low pressure port location?
    By larry325 in forum 3 Series BMW
    Last Post: 06-27-2006, 04:12 PM
  2. Looking to Buy 1994 525i what should I look for?
    By MD-11 Driver in forum 5 Series BMW
    Last Post: 02-06-2006, 09:11 AM
  3. 1994 525i OBC
    By GoldenEagleFan in forum 5 Series BMW
    Last Post: 01-28-2006, 05:21 PM
